IBM Planning analytics for Excel Session Time out
PrabhjotSinghPhull
OLAP Product: IBM PA
Version: 9.5
Post by PrabhjotSinghPhull »
Hi Team
three tier architecture i.e PAW in one server, CA in one server and PA in one server.
Windows server 2019
Paw version-2.0.80
I have referred the below article:
Step 1: navigated to PA sever path and opened the tm1web_config.xml as notepad.
Step 2: Added the parameter as HttpSessionTimeout = 15mins.
(refer the attached screenshot)
Result: opened the excel connected with server idle waited for 15 mins but the excel is not throwing error for session time out.
Refernces used :
Planning Analytics Spreadsheet Services (new TM1 Web):
Default: 20 minutes (default session-timeout in \tm1web\webapps\tm1web\WEB-INF\web.xml)
Location: \tm1web\webapps\tm1web\WEB-INF\configuration\tm1web_config.xml
Setting: HttpSessionTimeout
https://www.ibm.com/support/knowledgece ... meout.html
Please assist on this issue.
Prabhjot Singh
Re: IBM Planning analytics for Excel Session Time out
Your mail is rather unclear about which client session you are trying to impact.
You mention editing a config for PASS but then mention testing the connection time out in Excel.
For excel sessions you want the following both set in the tm1s.cfg
https://www.ibm.com/docs/en/planning-an ... outseconds
and
https://www.ibm.com/docs/en/planning-an ... outminutes
PrabhjotSinghPhull
Version: 9.5
Hi Steve
i have tired and added the parameter but its not working the session for excel is not getting timed out.
please do let me know if i need to try something else.
Screenshot 2024-06-05 124629.png (22.96 KiB) Viewed 3731 times
