I have two similar dimensions where the leaf level comprises shared elements.
Lets call them Dim-A and Dim-B.
Dim-A has a subset called 'product'.
Using MDX I would like to create a subset in Dim-B by referencing the named subset of Dim-A.
I understand this would require the Generate MDX function, and I have tried the following but it does not work.
Generate(
{TM1SubsetAll([Dim-A])},
Filter(
TM1SubsetToSet([Dim-B], "Product"),
[Dim-B].CurrentMember.Name = [Dim-A].CurrentMember.Name
I think I am missing a trick here.MDX error
Validation failed.
The server is temporarily unable to service your request due to a TM1 execution error. Please try again later or contact your administrator.
Can someone please help me to build this query.
Thanks in Advance.
Lav
