VBA References
Microsoft Scripting Runtime
Microsoft XML, v6.0
External Dependencies
https://github.com/VBA-tools/VBA-JSON
HTTP Post
Function TM1_Post(endPoint As String, payload As String)
Dim x As MSXML2.ServerXMLHTTP60
Set x = New MSXML2.ServerXMLHTTP60
x.Open "POST", "https://Your_Server:Your_Port" & endPoint, False, "Basic_Auth_Username", "Basic_Auth_Password"
'Additional http info is needed for other auth methods, consult IBM TM1 REST API documentation
x.setRequestHeader "WWW-Authenticate: Basic Realm", "TM1"
x.setRequestHeader "Content-Type", "application/json"
x.setRequestHeader "Accept", "application/json"
x.setRequestHeader "Prefer", "wait"
x.SetOption 2, 13056 'Bypass HTTPS cert authentication (internal network)
x.Send payload
TM1_Post = x.responseText
End Function
Function TM1_Run_Process(processName As String, Optional paramDictionary As Dictionary) As String
Dim payload As String
payload = ""
Dim runStatus As String
runStatus = ""
On Error GoTo ErrHandler
If Not paramDictionary Is Nothing Then
payload = "{""Parameters"":["
For Each Key In paramDictionary.Keys
payload = payload & "{""Name"":""" & Key & """, ""Value"":""" & paramDictionary(Key) & """},"
Next
payload = payload & "]}"
End If
Dim responseText As String
responseText = TM1_Post("/api/v1/Processes('" & processName & "')/tm1.ExecuteWithReturn", payload)
Dim json As Object
Set json = JsonConverter.ParseJson(responseText)
runStatus = json("ProcessExecuteStatusCode")
ErrHandler:
If Err.Number <> 0 Then
runStatus = Err.Description
End If
If runStatus <> "CompletedSuccessfully" Then
MsgBox "Turbo Integrator script error!: " & responseText
End If
TM1_Run_Process = runStatus
End FunctionCode: Select all
Sub Run_Your_Turbo_Integrator_Script()
Dim parameters As New Dictionary
parameters.Add "Your_Parameter_1", ThisWorkbook.Names("parameter1").RefersToRange.Value
parameters.Add "Your_Parameter_2", ThisWorkbook.Names("parameter2").RefersToRange.Value
parameters.Add "Your_Parameter_3", ThisWorkbook.Names("parameter3").RefersToRange.Value
parameters.Add "Your_Parameter_4", ThisWorkbook.Names("parameter4").RefersToRange.Value
'parameters.Add ...
Debug.Print TM1_Run_Process("Your_Turbo_Integrator_Process_Name", parameters)
parameters.RemoveAll
End Sub
