TM1Web Supress filters that lead to empty tables
Thjodolf
Excel Version: 2303
Post by Thjodolf »
I have an issue with a websheet in TM1-Web.
In the websheet I have a filter where users can choose any element from an account-dimension.
I used the SUBNM-formula without subset.
Problem is, users can pick elements resulting in an empty data-table.
I hoped, supressing zeros would fix it (which it didn't). :)
Is it achievable to only offer elements of a dimension that contain values for the data-table to avoid empty data-tables?
Re: TM1Web Supress filters that lead to empty tables
Yes. Use a subset name in your SUBNM towards a public dynamic subset (calculated with an MDX statement).
For instance,
Filter( TM1FilterByLevel( TM1SubsetAll( [BS_Account] ), 0), [BalanceSheet].([FIN_Year].[2022],[FIN_Period].[P07],[FIN_Scenario].[Actual],[BS_Measures].[Amount]) <> 0)
This would filter balance sheet accounts that have a non-zero balance in the balance sheet cube.
The values for other dimensions like year and period could come from Excel cells or other cube cells (like a system cube).
Thjodolf
Excel Version: 2303
Post by Thjodolf »
Hi Wim,
thanks for your answer and sorry I respond so late (was on vacation).
I didn't think of your solution and it works very well.
