Add an element to a control dimension with non-Admin user ID?
syd
OLAP Product: PA/TM1, CX
Version: PA 2.0
Excel Version: MSO 365
Post by syd »
Hello All,
Is there a way to add an element to }Groups dimension with non-admin/non-dataadmin user?
Thank you,
syd
PavoGa
Excel Version: 2013 PAW
Re: Add an element to a control dimension with non-Admin user ID?
Post by PavoGa »
If you have a TI with security access checked, I think you can.
Ty
Cleveland, TN
syd
Version: PA 2.0
Post by syd »
It did not work.
==> Execution was aborted. No Security Access for "DimensionElementInsert".
Thank you,
syd
MarenC
Excel Version: Excel 2016
Post by MarenC »
You need to use the AddGroup function, not dimensionelementinsert.
Maren
Version: PA 2.0.7
Post by jim wood »
Moved to the correct forum. :)
MarenC wrote: Wed Mar 22, 2023 5:35 pm Hi,
Maren
DimensionElementInsert or AddGroup will work; the }Groups dimension is a dimension just like any other.
Similar to how you can use CellPutS on the }ClientGroups cube instead of AssignClientToGroup - the difference is that the designated functions also "refresh" the security model by default; whereas if you use the standard functions you will need to run a SecurityRefresh function as well.
syd wrote: Wed Mar 22, 2023 4:18 pm It did not work.
This specific error "No Security Access" occurs when a non-admin user runs a TI process that contains "ADMIN" activities.
You can get around this by right-clicking on the process and ticking "Enable Security Access".
With that enabled the process will allow non-admin users to run it and action the admin tasks within the process.
MarenC
Post by MarenC »
Hi declan,
thanks for the info, but I decided to assume that they had enabled security access, given this was the advice provided by PavoGo. And I thought, well why not use AddGroups for this, maybe they are unaware of it...!
I was still expecting the error message to occur in all honesty, as I thought the issue was indeed that they had not bothered to follow the advice given (or didn't understand what was being hinted at).
Your advice is more specific, and probably more helpful!
Maren
syd
Version: PA 2.0
Post by syd »
declanr wrote: Wed Mar 22, 2023 9:14 pm
Maren
I totally missed this Enabling the Security Access Option for a Process. After enabling this, it worked.
Thank you,
syd
