Order set in prolog tab in a view created with MDX is no the order running in datatab
jjramirez
OLAP Product: IBM Planning Analytics/TM1
Version: 2.0.9.15
Excel Version: Excel 2019
Post by jjramirez »
Hi everybody,
I created a view in the prolog tab using a MDX to filter and order a dimension from the source cube
and when I test the MDX in subset editor the elements are shown in the expected order even in the view created by the TI Process elements appears in the expected order but when process go to data tab elements are processed in ASC order...and not as the MDX.
sMDXGrua= '{ORDER( {Filter( { TM1FilterByLevel ( { TM1DrillDownMember ( { [Grua].[Gruas Muelle] },ALL,Recursive) } ,0 ) }
, [R.Operacion.Grua].([R_Version].[ ' | pVersion | ' ], [Periodo.E].[ ' | pPeriodo | ' ], [GPC.Empresa].[ ' | pEmpresa | ' ] ,[Acuerdo].[ ' | pAcuerdo | ' ] , [Grua].CurrentMember, [UVI].[ Total UVIs ],[Medida.Grua].[% Utilizacion Equipo] ) >0 )}
, [R.Operacion.Grua].([R_Version].[ ' | pVersion | ' ], [Periodo.E].[ ' | pPeriodo | ' ], [GPC.Empresa].[ ' | pEmpresa | ' ] ,[Acuerdo].[ ' | pAcuerdo | ' ] , [Grua].CurrentMember, [UVI].[ Total UVIs ],[Medida.Grua].[% Utilizacion Equipo] ),BDESC )}' ;
In pictures attached you can see
1) the order that subset editor return and the order: (26,28,29,27,25...)
2) the order that view created by TI return: (26,28,29,27,25...)
3) the order processed in datatab: (23,24,25,26)
Thank you veru much for any help!
results in subset editor.png (56.81 KiB) Viewed 914 times
view created by TI Process.png (40.1 KiB) Viewed 914 times
final view with TI Process results.png (27.43 KiB) Viewed 914 times
Re: Order set in prolog tab in a view created with MDX is no the order running in datatab
Check out this thread
jjramirez
Version: 2.0.9.15
Post by jjramirez »
Hi gtonkin,
thanks for your reference. I found a solution creating the subset and looping in the prolog tab instead of using the source view.
Version: PAL 2.0.9.18
Indeed looping the alternative, unless you need to go through a lot of sparsity or largish volumes or rules-calculated cells.
IBM Champion 2024
Is this the same thing as view dimension order though?
OP seems to be talking about element order within the a set being different depending on how the view is accessed?
Since all the other dimensions are pick of single members I can't see why dimension order of view would be impact the set order?
Looks like I jumped the gun here and assumed the current MDX view discussion.
Does look curious - What is set in prolog for the DataSourceNameForServer etc? Need to see what is happening in prolog to build and reference the set.
