Hello. I am trying to return my Time dimension's "Month Status" attribute value in the results of this MDX statement:
SELECT non empty {[Scenario].[Scenario].[Budget]} on 0,
non empty
{TM1FILTERBYLEVEL(TM1SUBSETALL([Supplements].[Supplements]) , 0)}
* {TM1FILTERBYLEVEL(TM1SUBSETALL([Time].[Time]) , 0)}
DIMENSION PROPERTIES [Time].[Time].[Month Status]
on 1
from [Programs] where ([Currency].[Currency].[USD], [Programs Measure].[Programs Measure].[Total Revenue])
However I only get 3 columns returning data for Supplements, Time and Scenario...I was expecting a 4th column for the Time dimension's Month Status string attribute. Is something wrong with my syntax?
Returning attribute value for MDX statement
Re: Returning attribute value for MDX statement
If your interface is PAW or PAX you could just right click on the time dimension in the view and select show attributes. That is the quick GUI friendly way to show what you want.
If you want it to be part of the view that will work in other interfaces also then I would do it by using a MEMBER calculation.
WITH MEMBER [Scenario].[Scenario].[Month Status]
AS [Time].[Time].CurrentMember.Properties("Month Status")
SELECT non empty {UNION( {[Scenario].[Scenario].[Budget]}, {[Scenario].[Scenario].[Month Status]} )} on 0,
non empty
* {TM1FILTERBYLEVEL(TM1SUBSETALL([Time].[Time]) , 0)} on 1
tm1dev
- Version: Planning Analytics 2.x
Thank you declanr, that worked! I am using the Rest API to return data with this MDx statement.
