When I try to start the service, I get the error 1067
also when I give a service user admin rights, this error comes up
[Save TM1 Server configuration].
The data directory exists.
The TM1 Server configuration is available.
The TM1 server configuration is available.
[Startup]
[ ERROR ] startup_tm1s.bat D:/TM1_2022_DP/Data
TM1 Configuration Path is D:\TM1_2022_DP/data
TM1 Server Name is bis_2022_DP
TM1_SERVICE_ID is default
BINARY_PATH_NAME : "C:\Program Files\ibm\cognos\tm1_64\bin64\tm1sd.exe"
The service "IBM Cognos TM1 Server - bis_2022_DP" is registered
errorlevel 0 exit 0
TM1 Configuration Path is D:\TM1_2022_DP\Data
Starting the service "IBM Cognos TM1 Server - bis_2022_DP" ...
IBM Cognos TM1 Server - bis_2022_DP is started.
errorlevel 1 exit 1
IBM Cognos TM1 Server - bis_2022_DP could not be started.
A system error occurred.
System error 1067 occurred.
The process was terminated unexpectedly.
