About drill through Suppress Zero issue
- Version: PA 2.09 / TM1 11.7.00000.42
- Excel Version: EXCEL 2019
I don't know if anyone has seen this before, i have write "ViewExtractSkipZeroesSet (cCubTarget, cViewTarget , 1);" in the custom }drill_process, the driller still sees a view that contains 0
- gtonkin
Re: About drill through Suppress Zero issue
Have you tried ViewSuppressZeroesSet ?
Thank you very much, after i add "ViewSuppressZeroesSet(cCubTarget, cViewTarget , 1);" it works.
And ask another question : what's the difference between "ViewSuppressZeroesSet" and "ViewExtractSkipZeroesSet",
i think they both use to supressZero.
Any help would be greatly appreciated.
- gtonkin
ViewSuppressZeroesSet is used to suppress zeroes in views that users would open.
ViewExtractSkipZeroesSet would suppress zeroes in views used in TI as a datasource for processing - may be extracting via Asciioutput, updating same or other cubes etc.
i get it , thank u again
