TM1 RULE not consolidating
DYNA
OLAP Product: PLANNING ANALYTICS (TM1)
Version: 2.0.6
Excel Version: Excel for office 365
Post by DYNA »
Good day All,
I am having a challenge with the following rule
['Opening Balance'] = If((ATTRS('Calendar',!Calendar , 'IsMonthApril')@='Y' & ATTRS('Account - MDA', !Account - MDA, 'Flags')@='Y') ,0,DB('MDA Trial Balance ',!Calendar,!Version,!Data Source,!Client,!Property Sector,!Property Grade,!Property,!Account - MDA,'Opening Balance'));
I am trying to make opening balance zero since it is the beginning of the financial year , the rule does return the zeros for the specified cells but doesn't consolidate to the top level.
when i specify N: it doesn't not work at all .
Any direction or help would be much appreciated
Version: PAL 2.0.9.10
Re: TM1 RULE not consolidating
Did you use feeders ? And correctly ?
https://www.wimgielis.com ==> 120 TM1 articles and a lot of custom code
Newest blog article: Documenting processes and rules https://github.com/wimgielis
MarenC
Excel Version: Excel 2016
Post by MarenC »
Is MDA Trial Balance a different cube to the cube the rule is in?
Maren
DYNA
Version: 2.0.6
Post by DYNA »
Thanks for responding , Actually I request an assistance with feeding this rule
Yes , MDA TRIAL BALANCE is different cube.
konstantin-spb
Version: PA 2.0.9
Post by konstantin-spb »
Try something like this:
Source cube (in your code with a SPACE at the end of the cube name?):
FEEDERS;
['Opening Balance'] => DB(
    IF( ATTRS('Calendar', !Calendar, 'IsMonthApril') @= 'Y' & ATTRS('Account - MDA', !Account - MDA, 'Flags') @= 'Y',
    'Unnamed Cube', !Calendar, !Version, !Data Source, !Client, !Property Sector, !Property Grade, !Property, !Account - MDA, 'Opening Balance') ;
Target cube:
'Unnamed Cube'
FEEDSTRINGS;
SKIPCHECK;
['Opening Balance'] = N:
        0,
    DB('MDA Trial Balance ', !Calendar, !Version, !Data Source, !Client, !Property Sector, !Property Grade, !Property, !Account - MDA, 'Opening Balance') );
