Just playing around a bit...
Yet another method to transfer data to TM1 (although there are abviously better methods out there).
Open a view in a cube viewer (for instance using Architect) and put your cursor on a cell where you'd want to copy a bunch of cells from Excel.
Use a bit of code in VBA:
Sub CopyToTM1()
[A1].Copy 'or: [B2].CurrentRegion.Copy, or refer to another sheet, or make it even more dynamic
AppActivate "Cube Viewer: SERVER NAME->CUBE NAME->VIEW NAME" 'change over here: it should be the window caption of your cube view
Application.SendKeys "^v" 'mimick Ctrl-V
AppActivate Application.Caption
Application.CutCopyMode = False 'take away the ants trace
End SubCode: Select all
Sub CopyToTM1()
Dim DataObj As New MSForms.DataObject
DataObj.SetText 1000
DataObj.PutInClipboard
End Subor simply:
Sub CopyToTM1()
Application.SendKeys "1000"
End SubWim
