Audit Logs & Trails for 9.4 & above
appleglaze28
Post by appleglaze28 »
I'd like to ask what are the available audit trails available for TM1 in 9.4 and above. Is there any difference with TM1 9.1 SP3?
Is the Audit log the one with the file name tm1auditstorexxxxxxx? Is there anyway to understand this log better? Are TM1 Pespective & Executive View share the same audit log if you have both or different?
Is there no indication what time, a certain item happened? Or can you like create audit logs per day cause right now I'm not sure what the numbers on the left side is?
For concurrent multiple users, the audit logs every change per person separately for that instance on logging in or does it log it base on the time?
Re: Audit Logs & Trails for 9.4 & above
Post by David Usherwood »
Errmmmm...
Though I do my best to avoid 9.4, preferring stability to whizzy features, my recollection is that the log files are readable through the frontend without problems. Looking at your sample it doesn't look too hard to process into a better shape though.
appleglaze28
Altough part of it is easy to read...what if I need a timestamp for reference, and currently I don't see a date stamp of every changes.
Are the capacity of the audit logs dependent on settings you set on the tm1.cfg file? or can you set it to create daily logs cause even the creation of the log files is hard to read without any date separator on the audit log. I was thinking would it be possible to create logs every day end.
