PAX RefreshAllData()
RonLat
OLAP Product: TM1, Planning Analytics
Version: 2.0
Excel Version: 365
Post by RonLat »
There is a function in PAX that allows to refresh the DBRW formula in a excel worksheet using VBA.
Preparations
  • The file CognosOfficeAutomationExample.bas is imported into the VBA project
  • The file CognosOfficeMessageSuppressor.cls is imported into the VBA project
  • PAX is connected to the TM1 server
  • A view from the Sdata cube is present in the worksheet (DBRW formulas)
Example 1
Sub refreshData()
    CognosOfficeAutomationObject.RefreshAllData
End Sub
Result: Run time error '424': object required
Example 2
Sub refreshData()
  ActiveWorkbook.Worksheets("TAB1").CognosOfficeAutomationObject.RefreshAllData
End Sub
Result: Run-time error 438: Object doesn't support this property or method
Example 3
Sub CalculateOneWorksheet()
  ActiveWorkbook.Worksheets("TAB1").Calculate
End Sub
Result: The normal VBA function Calculate runs without errors, does not update the DBRW formulas though.
Does anybody have a hint how to use the RefreshAllData function with PAX in VBA?
Version: PAL 2.0.9.10; PAW 2.0.71
Re: PAX RefreshAllData()
Example 1 works in my books.
I had an issue previously with the IBM Framework for Office clashing with something when I updated to PAW 2.0.65
What version are you on? Did you previously enable the IBM Framework for Office as a COM add-in as well?
With PAfE 2.0.65 onwards, make sure that all PAfE and the IBM framework have been uninstalled.
I had an issue where my installation was not showing in Add or Remove Programs and I had to run the Uninstall from the folder in C:\Program Files\ibm\cognos\. Once this was removed and I restarted Excel with PAfE, in my case 2.0.67, all worked as expected.
flecky
Version: PAoC
Post by flecky »
I was having issues with refreshing data using VBA but I found something on the ibm git page https://ibm.github.io/paxapi/#refreshsheet
Application.COMAddIns("CognosOffice12.Connect").Object.AutomationServer.Application("COR", "1.1").RefreshSheet
I use as a simple refresh and also for dynamic report rebuilds in PAfE 2.0.68. In the VBA itself I have never imported CognosOfficeAutomationExample.bas or CognosOfficeMessageSuppressor.cls into the project but it seems to work fine and has done for the last few versions at least.
RonLat
Version: 2.0
Excel Version: 365
Post by RonLat »
Environment
  • Microsoft Excel for Microsoft 365 MSO (16.0.13127.21210) 32-Bit
  • IBM Planning Analytics for Microsoft Excel Version 2.0.68.4
  • Aktive COM-Add-In: IBM Planning Analytics for Excel Addin
  • Aktive COM-Add-In: IBM Planning Analytics for Excel Addin (Custom Task Pane Helper)
What I tried so far:
Sub refreshData()
    ' Application.COMAddIns("CognosOffice12.Connect").Object.AutomationServer.Application("COR", "1.1").RefreshBook
    ' Application.COMAddIns("CognosOffice12.Connect").Object.AutomationServer.Application("COR", "1.1").RefreshAllData
    ' Application.COMAddIns("CognosOffice12.Connect").Object.AutomationServer.RefreshAllData
End Sub
When I hit the F5 key within the Sub in the VBA editor, in all cases I get the error
Runtime error '91': Object variable or With block variable not set"
What do they mean by "Object variable" or "With block variable" that needs to be set?
I wonder also, how VBA would know which sheet to refresh, if I only say RefreshSheet?
RonLat
Version: 2.0
Excel Version: 365
Post by RonLat »
I tried to check, what COMAddins are installed on my system.
Sub refreshData()
    Dim var1
    For Each var1 In Application.COMAddIns
        Debug.Print var1
    Next
End Sub
Result
  • Microsoft Power View for Excel
  • IBM Framework for Office
  • IBM Planning Analytics for Excel Addin
  • Microsoft Power Map for Excel
  • IBM Planning Analytics for Excel Addin (Custom Task Pane Helper)
  • Microsoft Data Streamer for Excel
  • Inquire
  • Microsoft Power Pivot for Excel
There ist no CognosOffice12 in this list, so
can not work at all. What's the deal with the CognosOffice12? Where does it come from?
Still fairly certain that you need to uninstall IBM framework for Office as you are running PAfE 2.0.68
RonLat
Version: 2.0
Excel Version: 365
Post by RonLat »
There is a workaround regarding this problem and it is described only in one place on the internet.
IBM Framework for Office and PAfE 2.0.66 installs.
https://community.ibm.com/community/use ... gestviewer
Old PAX: CognosOffice12.Connect
New PAfE: CognosOffice12.ConnectPAfEAddin
Working calls of the refresh functions:
Sub refreshData()
   ' Call over object variable
    Dim CognosOfficeAutomationObject As Object
    Set CognosOfficeAutomationObject = Application.COMAddIns("CognosOffice12.ConnectPAfEAddin").Object.AutomationServer
    ' direct call
    Application.COMAddIns("CognosOffice12.ConnectPAfEAddin").Object.AutomationServer.Application("COR", "1.1").RefreshBook
    Application.COMAddIns("CognosOffice12.ConnectPAfEAddin").Object.AutomationServer.Application("COR", "1.1").RefreshSheet
    Application.COMAddIns("CognosOffice12.ConnectPAfEAddin").Object.AutomationServer.RefreshAllData
End Sub
So, for now the problem is kinda solved, till IBM changes something in the near future and it crashes again :-)
Paul Segal
Version: TM1 11 and up
Post by Paul Segal »
Although if you read the whole link, this shouldn't be necessary. I'd be more concerned with getting the install right rather than amending the VBA code to partially fix something that's broken (and might fix itself in future, then giving you an issue with the VBA code that now no longer works).
Paul
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
I've had another RefreshAllData fault with "91" error recently: DAX add-in caused this. Disabling it fixed the error
TM1 and Data Science blog: 6th article - PAfE + VBA: Commit each cell without pressing “Commit” button.
