PAX API: Multiple commit of all quick reports (or other ways?)
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
Hello everybody!
The Commit button commits data only in active sheet, so I'm asked to make a button to commit the entire book.
Firstly, maybe there is an option to make the Commit button commit the entire book (like the "Refresh" one)?
Secondly, I've made a VBA script to do this. The idea is to loop through all "tm1\\_X_R" named ranges to point the rows of each report book and to commit it
Option Explicit
Option Compare Text
Sub CommitAll()
Dim nm As Name
Dim sFilters As String
Dim sRange As String
sFilters = "_R"
    For Each nm In ActiveWorkbook.Names
'Locate "tm1\\_X_R" named range
        If InStr(nm.Name, sFilters) > 1 Then
            sRange = nm.Name
'Print where we are
            Debug.Print (sRange)
            Reporting.GetCurrentReport(Range(sRange)).Commit True
            Reporting.Wait
        End If
    Next nm
End Sub
This VBA throws error: "Run-time error '91': Object variable or With block varible not set". The most strange thing is that the error is thrown on different quick reports each time I relaunch excel.
Appreciate any help on this.
Or, if somebody has working VBA for this - please share.
Re: PAX API: Multiple commit of all quick reports (or other ways?)
Hi Alexander, Still very much a hack at this but you could try something like:
Sub CommitQuickReports()
Dim oReport As Variant
Dim iReportCount As Integer
Dim iReportIndex As Integer
'Get number of reports in the book
iReportCount = Reporting.getreports().Count
For iReportIndex = 0 To iReportCount - 1
    Set oReport = Reporting.GetReports().Item(iReportIndex)
    Debug.Print oReport.Name
    oReport.Commit True
    Reporting.Wait
Next
End Sub
HTH
BR, George.
Adam
OLAP Product: IBM PA
Version: 2.0.9.x
Post by Adam »
We've been using the below in production for quite a while. Note the lack of .Wait
Sub CommitAllQuickReports()
    Dim currentNamedRange As Name
    Dim qrIDNumberWIP As String
    Dim qrIDNumber As Long
    For Each currentNamedRange In ActiveWorkbook.Names
		If currentNamedRange.Name Like "tm1\\_*_C" Then
			qrIDNumberWIP = Mid(currentNamedRange.Name, 7)
			qrIDNumberWIP = Mid(qrIDNumberWIP, 1, InStr(1, qrIDNumberWIP, "_") - 1)
			qrIDNumber = CLng(qrIDNumberWIP)
			Reporting.QuickReports.Get(qrIDNumber).Commit
		End If
	Next
End Sub
Take care,
Adam
Hi Adam, Alexander,
Just a small remark. Names have a Comment field, that is exposed through VBA. Maybe useful to use that one rather than the string manipulations. Not for speed but rather ease of use/maintainability/flexibility.
In general, this Comment field and also controls that expose a .Tag property, are useful candidates to store this kind of information.
? Names("test_5_range").Comment
5
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
Thanks George, Adam, Wim,
Geroge's variant looks the most elegant, and it works. And as Adam said, "Wait" is not needed. My final code is:
Sub CommitAll()
iReportCount = Reporting.GetReports().Count
    oReport.Commit True
Next
End Sub
