TM1 formulas to values in VBA with PAFE API
Hello all,
I am quite sure I posted about this topic some time ago but I cannot find back the topic.
Here is working code in VBA PAFE. Of course, the usefulness is somewhat less compared to zapping TM1 formulas in Perspectives since the PAFE ribbon has buttons to click on. But there are still advantages in my code :D
Enum ScopeToInspect
    All_Workbooks = 0
    Active_Workbook = 1
    Active_Sheet = 2
    Current_Selection = 3
End Enum
Sub TM1_DB_to_values_PAFE()
    ' PURPOSE:
    ' change cells with TM1 formulas to values
    ' ONLY TO BE USED IN PAFE, NOT PERSPECTIVES
    Dim wb                    As Workbook
    Dim ws                    As Worksheet
    Dim m1                    As Boolean
    Dim m2                    As XlCalculation
    Dim iScopeToInspect       As ScopeToInspect
    Dim o                     As Object
    iScopeToInspect = -1
    On Error Resume Next
    iScopeToInspect = InputBox("Where do you want to search for TM1 formulas:" & vbNewLine & vbNewLine & _
                               "(0) all sheets in all open workbooks" & vbNewLine & _
                               "(1) all sheets in the active workbook" & vbNewLine & _
                               "(2) the active worksheet" & vbNewLine & _
                               "(3) the current selection", "Scope", 2)
    If iScopeToInspect = -1 Then Exit Sub
    Set o = Application.COMAddIns("CognosOffice12.Connect").object.AutomationServer.Application("COR", "1.1")
    m1 = Application.ScreenUpdating
    If m1 Then Application.ScreenUpdating = False
    m2 = Application.Calculation
    If m2 <> xlCalculationManual Then Application.Calculation = xlCalculationManual
    Select Case iScopeToInspect
    Case All_Workbooks
        'loop through all workbooks in the application
        For Each wb In Application.Workbooks
            wb.Activate
            o.UnlinkBook
        Next
    Case Active_Workbook: o.UnlinkBook
    Case Active_Sheet: o.UnlinkSheet
    Case Current_Selection: o.UnlinkSelection
    End Select
    If Application.ScreenUpdating <> m1 Then Application.ScreenUpdating = m1
    If Application.Calculation <> m2 Then Application.Calculation = m2
End Sub
For some of the choices, PAFE will throw a message box for confirmation.
If anyone knows a way to skip this msgbox, please let me know.
Have a good weekend !
Paul Segal
Version: TM1 11 and up
Re: TM1 formulas to values in VBA with PAFE API
Post by Paul Segal »
Hi Wim,
It's version-related - from 11.0.56 I don't think it will give you the confirmation messages.
Paul
Paul Segal wrote: Mon Apr 12, 2021 3:45 pm Hi Wim,
Thanks Paul. I have PAFE version 61 on my own laptop and it still gives the confirmation msgbox'es.
Wim Gielis wrote: Mon Apr 12, 2021 5:46 pm
Got it. It’s Application.DisplayAlerts = False :roll: :lol:
