Migrate ActiveForm from Perspectives to PAfE / PAX
Mark2007
Version: PA 2
Excel Version: office 365
Post by Mark2007 »
Hi there,
I tried an existing Report with ActiveForm (created with Perspectives and working great with Perspectives) in PAX, but in PAX / PAfE, it doesn't work.
What I tried right now:
The ranges in PAfE are differently named than in Perspectives: TM1RPTFMTIDCOL, PAX: TM1RPTFMTIDCOL1 - I did it
There are some new ranges in ActiveForms in PAfE: - TM1RPTQRYRNG1 and TM1RPTVIEWRNG1 - I defined them
There's a new Sheet (very hidden) in PAfE: Cognos_Office_Connection_Cache - but I think this is created automatically.
Any idea what else has to be done to make an activeForm work in PAfE?
PA-Server: PA 2.07
Excel Office 365 ProPlus, Version 2002 (Build 12527.21504)
PAfE: COR_APP_version=COR_APP-AW32-ML-RTM-11.0.58.7-0
Thanks!
Mark
Re: Migrate ActiveForm from Perspectives to PAfE / PAX
Hi Mark, In what manner doesn't it work?
Do you have back and forth to TM1 whilst determining references (i.e. things link Dimnm, DImix, DBS, etc etc)?
HI Mark,
There were one or two minor changes but have been able to get my old Active forms working in PAX with a few reviews and updates.
Where I have a TM1RPTROW formula, I try and reference a subset or if MDX, put the MDX in a cell to make it easy to view and update.
If you have used the set editor to create a set, PAfE will create the MDX and allocate it to a named range.
The named range is hidden and you would need to unhide it if you want to have sight of it.
In terms of the other identifiers e.g. TM1RPTFMTIDCOL1, the 1 is just the name of the Dynamic Report.
I usually edit the TM1RPTVIEW formula and update the name to something friendly i.e. =@TM1RPTVIEW("SDate:Sales Planning:Input"...) if this were an input sheet.
If you do change the name, edit the named ranges and update them accordingly too.
When you look at the Workbook tab on the PAfE Task Pane, at least the Dynamic reports will be meaningful too.
TM1RPTQRYRNG should be for your filter i.e. sorting, Top N, Bottom N etc. Previously I think you could just put the filter formula in to any random cell.
The Cognos_Office_Connection_Cache is used for the list of items tied to the data validations i.e. when you have a SUBNM or picklist cell, the members are returned to this sheet and linked to a named range called cafe_validation_temp
With the above in mind, I would first check that all the named ranges are valid for the Dynamic Report then check the TM1RPTROW to confirm that if you edit the set, it opens the editor etc.
Other issues may be TM1RPTTITLE references in the TM1RPTVIEWRNG that are invalid or are not necessary as they do not point to members that are in the "context area".
HTH
BR, George.
Mark2007
Version: PA 2
Post by Mark2007 »
Steve Rowe wrote: Mon Feb 22, 2021 5:48 pm Hi Mark, In what manner doesn't it work?
Hi Steve,
"it does not work" means: no lines in the ActiveForm are generated, and the first line keeps empty.
my report consists of two parts. In the upper, there is a summary with fixed lines and dbrw-formula. below, there is the activeform which dbrw-formulars are referencing to the same Subnm-Formulas as the fixed part.
If I open the report in Perspectives and actualize via <Alt> and <F9>, the lines are generated, so I think there's no general problem in the formulas.
Mark
Mark2007
Version: PA 2
Post by Mark2007 »
Thanks for your help!
the good news was that there is no big issue I should focus. So I went through all TM1RPTRow-Formulas on the sheet (I have 5 of them).
four of the TM1RPTROW-Formulas included everything: A link to a subset (the cell is empty), a link to an element (the cell is empty) and a link to a mdx-statement (the cell is filled)
I thought that shouldn't be a problem - but it was.
I removed the link to the element, and now it works.
Might be a bug in PAfE, but now it woks.
Mark2007 wrote: Tue Feb 23, 2021 9:44 amfour of the TM1RPTROW-Formulas included everything: A link to a subset (the cell is empty), a link to an element (the cell is empty) and a link to a mdx-statement (the cell is filled)
Actually, I have never ever done that. All my TM1RPTROW formulas always use only 1 option.
