TM1Web URL API and Action Button Issue
mce
Excel Version: 2013 2016
Post by mce »
We have a problem with URL API and actions buttons in TM1Web.
When a websheet is opened via URL API, the action buttons that open other websheets or other sheets of the same tm1workbook does not work. Anyone avare of this issue? What is the solution?
I need to get websheet opened via URL API but then the user should be able to open other websheets by pressing the action button in that websheet.
version: PA.2.0.9.1
ykud
Re: TM1Web URL API and Action Button Issue
Post by ykud »
Ah, I can see you raised in a couple of topics :)
It's a bug, raise a ticket with IBM support, we had it fixed in some iteration of 2.0.6. I thought the fix would be incorporated in 2.0.9.1, but it apparently isn't :(
I wish they would fix the context menu options for websheets or cube views opened via URL API. The fact that you have no spreading menu and can't drill-through from windows that are opened via URL API severely limits applications you can build with TM1Web.
Every time we have raised this though we always get the response that the omission is by design and hence it's a "feature" rather than a bug.
ykud
Post by ykud »
lotsaram wrote: Mon Jun 15, 2020 7:08 am I wish they would fix the context menu options for websheets or cube views opened via URL API. The fact that you have no spreading menu and can't drill-through from windows that are opened via URL API severely limits applications you can build with TM1Web.
Yep, this killed the drill-down functionality for me a long while back. Very annoying.
Don't think they'll ever change this, given the 'replacing Tm1web with spreadsheet service within PaW' direction.
mce
Post by mce »
Thanks for the comments. Could you note of the APAR number for the fix you get in 2.0.6 so that we can refer to the same issue and tell them it is appearing in the latest version as well. When we tested this in 2.0.8, we saw that this problem is there as well.
ykud wrote: Sun Jun 14, 2020 11:28 pm Ah, I can see you raised in a couple of topics :)
ykud
Post by ykud »
mce wrote: Mon Jun 15, 2020 1:36 pm Thanks for the comments. Could you note of the APAR number for the fix you get in 2.0.6 so that we can refer to the same issue and tell them it is appearing in the latest version as well. When we tested this in 2.0.8, we saw that this problem is there as well
https://www.ibm.com/support/pages/apar/PH14637
PH14637: ACTIONBUTTON'S OPTION "GO TO ANOTHER WORKSHEET" DOESN'T WORK IN WORKSHEET WAS OPENED WITH URLAPI PA 2.0.6 IF15
it's marked as addressed in 2.0.9.1 fix list:
https://www.ibm.com/support/pages/sites ... 1%20v3.pdf
mce
Post by mce »
I now realized that IBM's PA demo environment is not 2.0.9.1. It is an IF of 2.0.9. Hence it does not have this fix there. Will check it in 2.0.9.1 separately.
