What is correct way to write TM1 rule.
Ashleigh W
Version: TM1 Perspectives 10
Excel Version: Excel 2016
Post by Ashleigh W »
Hi Experts, 'm back with a question.
I'm confused on how to place dynamic objects on Left side of rule. I tried below but it errors. I actually want the right side to be a look up from another cube.
[!}Cubes, !}Groups] = S: 'READ';
do i write as below?
[] = S: DB('my_cube', !}Cubes, !}Groups, 'Permission');
thanks in advance.
ascheevel
Version: PA 2.0.9.1
Excel Version: 365
Re: What is correct way to write TM1 rule.
Post by ascheevel »
Did you try the second option you noted and did it work?
Ashleigh W
thanks, second option seem to work yes.
Is there any way to refer to elements in below fashion (LEFT Side) ?
ascheevel
Version: PA 2.0.9.1
Excel Version: 365
Post by ascheevel »
Ashleigh W wrote: ↑Mon Mar 30, 2020 2:51 pm [!}Cubes, !}Groups] = S: 'READ';
Assuming then that your cube has dimensions "}Cubes" and "}Groups"? What you've written is the same as:
[] = S:'READ';
Dynamic on the left would just be referencing itself and would always apply. Perhaps you can share more details around what you're trying to accomplish and why you think dynamic on the left is needed. AFIAK, !<dim> on the left doesn't work in rules because it'd be the same as [].
Said another way, the !<dim> is already implied on the left for a rule that doesn't explicitly specify elements for that dimension. For example, if you have a 4 dim sales cube: Customer, Product, Time, Measure and the measure dim has measures like "quantity", "price", and "total sales". If you wrote a rule for Total Sales to be equal to quantity times price, the rule would look like this:
['Total Sales'] = N:['Quantity'] * ['Price'];
The measure dim is the only dim defined on the left side and the rule will therefore apply to all elements in all other dims. That's the same as if you could write the rule as:
[!Customer, !Product, !Time, 'Total Sales'] = N:['Quantity'] * ['Price'];
The !<dim> callouts on the left are already implied and therefore not needed. Perhaps this is the reason it's a not a valid way to write a rule.
If you keep in mind the logic for a rules statements is as follows:
[Area of cube] = Rule calculation
then you'll understand why you can't use dynamic values on the left hand side. If you don't specify a value on the left hand side of a rule for a specific dimension then it means all elements of that dimension. That's it, you either identify a specific value or ALL. If you want the assignment to be "dynamic" then you need to put it on the right-hand side and use IF logic.
Ashleigh W wrote: ↑Mon Mar 30, 2020 2:51 pm thanks, second option seem to work yes.
Yes. Any dimension omitted within square brackets (i.e. left hand OR right hand side) is implicitly unfiltered or "ALL". Or in other words same as !dimension within a DB() reference on the RHS.
Ashleigh W
Thanks ascheevel, tomok and lotsaram. Your answers gave me much more clarity.
