Pass a parameter to SQL stored procedure
CRP0021
Version: 10.3
Post by CRP0021 »
I'm looking for some advice on executing a SQL stored procedure from within a TI.
Here's what I've done.
I have a parameter ( pLoadNumber ) which is Numeric and the value will always change but for this example lets say the value is 100.0000
I need to pass this parameter to a stored procedure and I am using the ODBCOutput function.
The column Load_ID in the SQL table is stored as an int.
## EPILOG ##
sSP = 'EXEC [TM1ODBC].[data].[start_end_time] @load_id = Select pLoadNumber';
OdbcOutput ( cODBC, sSP );
# Close connection to ODBC source
OdbcClose ( cODBC );
I'm getting an error that says "Error converting datatype NVARCHAR to int" and I'm unsure how to amend the SQL statement to Convert or Cast to an int value.
Any help would be appreciated!
orlando
Version: PAL 2.0.8
Re: Pass a parameter to SQL stored procedure
Post by orlando »
CRP0021 wrote: Wed Feb 26, 2020 3:07 am
## EPILOG ##
there is no parameter in your query - the complete query is in quotation marks.
try this:
sSP = 'EXEC [TM1ODBC].[data].[start_end_time] @load_id = Select ' | pLoadNumber;
i'm not that used to sql at the moment but to you really need the "select" for @load_id. firt thought was
if pLoadNumber is eg. a 9 the parameter for @load_id is "select 9" and that is obviously a string
maybe this
sSP = 'EXEC [TM1ODBC].[data].[start_end_time] @load_id =' | pLoadNumber;
works propper
best regards
orlando
