Error with SSL and TM1 web
cdhodge2002
Post by cdhodge2002 »
I am having an error with TM1web, integrated login and SSL sites. Without SSL enabled on the IIS the integrated logon flawlessly, but once I turn on SSL the integrated login doesn't work and I get the following error:
Integrated Login Failed. Please Try Again... 80: TM1APIDOTNET Exception: - System Server Client Not Found
For some reason when I turn on SSL my credentials don't get passed to TM1web.
Michel Zijlema
OLAP Product: TM1, PALO
Version: both 2.5 and higher
Excel Version: 2003-2007-2010
Re: Error with SSL and TM1 web
Post by Michel Zijlema »
Did you check the web.config file for TM1Web regarding SSL and integrated login settings? See also this thread - do you have these settings OK?
Michel
