I have created a process using a cube view as the source and have dynamically built the view on the prolog and then in the same process I have updated the meta and data tabs.
So in the prolog I have the following to make this work:
DatasourceType = 'VIEW';
DatasourceNameForServer = vCube;
DatasourcecubeView = vName;
In other words I can put everything in one process.
However when I come to write a process using a text file it doesn't allow me to do this, so if I create the text file in the prolog and I put the following
DatasourceType = 'CHARACTERDELIMITED';
DatasourceNameForServer = vFile;
DatasourceNameForClient= vFile;
I can't update on the meta and data tabs because I get an error saying process aborted and it says unable to open data source. If I then run the process again it works because the file then exists.
Is there any way I can get this to work so I don't have to create multiple processes?
Maren
Difference between TI Text and Cube View
Re: Difference between TI Text and Cube View
You should just create a file manually with the same columns and a few lines. Like that you will have Variables and everything will work fine. The prolog tab can still set the data source in a dynamic way.
MarenC
- Excel Version: Excel 2016
Hi Wim,
I know I can create the file manually and it will work. The point is that I want to create the file in the prolog (using powershell) and then use this file created in the prolog in the meta and data tabs. I can do this when the data source is a cube view but not when it is a text file.
Maren
Maren
Do you have proper variables ?
MarenC
Hi Wim,
Yes I defined all the variables using a file I had already created.
This file was then deleted and the file is created in the prolog via powershell.
If I run the process it creates the file but then aborts saying it can't open the data source. If I immediately run the process again it works fine as it can now find the data source.
Maren
Maren
There should be no issue with creating the file in the prolog which you want to use as a datasource. TI does not try to access the datasource until the prolog is finished.
The issue you might have is that there is still a lock on the file.
- is the command line properly terminated?
- have you tried putting in a wait to allow PS to finish?
MarenC
That was the problem. I had ExecuteCommand(vCmd, 0), I changed to ExecuteCommand(vCmd, 1) and it worked okhave you tried putting in a wait to allow PS to finish?
Thank you very much
Maren
- PavoGa
- Excel Version: 2013 PAW
I do not know if this is what lotsaram was referring to, but an alternative is to use SLEEP(n) after the ExecuteCommand where n = milliseconds as another way of giving PS time to complete.
With ExecuteCommand, if something goes wrong in the called script and it gets hung up, your TI will sit there patiently waiting for it to complete when the second argument is set to "1".
Ty
Cleveland, TN
Cleveland, TN
MarenC
I updated to use sleep instead, thanks.
Maren
Maren
