setting up a new application on Architect
Rtel
Post by Rtel »
Hello, I have TM1 10.2.2 version and I am trying to create a new server named Sample.
I have TM1 server on AIX and client (Architect) installed on Windows 10 pro
1) After setting and copying TM1 config file, I start up my application using startup_tm1s.sh
2) The Sample server comes up in Architect.
Problem is when I double click on the server name the dialog box to login do not come up and I see on Top bar as 'Architect not responding'
I have client login set up through 'IBM Cognos Analytic' security.
Please advise.
Rtel
Re: setting up a new application on Architect
Rtel wrote: Mon Dec 03, 2018 8:25 pm copying TM1 config file
You changed the port number in the following setting, correct?
PortNumber=
Rtel
Post by Rtel »
Hi , Thanks for replying.
It did error out earlier then I changed port to a new number as follows
PortNumber=12396
Following is information in config file. datafile folder and logfiles are in the same folder (Sample) as the config file.
[TM1S]
DistributedPlanningOutputDir=tunit
PersistentFeeders=T
ForceReevaluationOfFeedersForFedCellsOnDataChange=T
DataBaseDirectory=datafiles
LoggingDirectory=logfiles
ServerName=Samples
PortNumber=12396
AdminHost=CON
IPAddress=Pointing to a valid IP address
Language=eng
Protocol=tcp
AllowSeparateNandCRules = T
NetworkFrame=
SaveTime=
DownTime=
RuleTraceOn=
MTQ=-2
maximumcubeloadthreads=4
RunningInBackground=T
log4j.appender.S1.TimeZone=LOCAL
IntegratedSecurityMode=5
ServerCAMURI=valid URL
ClientCAMURI=valid URL
CAMSSLCertificate=/opt/IBM/cognos/tm1_64/c11sslcert.cer
ClientPingCAMPassport=900
Is there anything else I am missing ?
Thanks in advance for your help.
