PAx - 404 error while try to open subset editor
Andy
Version: 2.05
Post by Andy »
Hi there,
is this forum I found a lot of similar problems but no solution which works for me.
I have Planning Analytics 2.05, PAx release 34, PAW release 34 and IE 11 installed.
Everything is working fine. Architect, performance Modeler, Application Web, PAW and almost PAx.
In Pax I can make a connection to my application and can create views.
Everyting is working, but when I double-click on a dimension element to change it I am getting a HTTP 404 error message "Webpage cannot be found".
I really hope that someone can help me out here.
Thanks in advance.
Re: PAx - 404 error while try to open subset editor
One of two things.
You have pointed PAx at the TM1 server, it needs to point at the PAW server.
or
You need to have at least IE11 for the web components of PAx to work.
hankler
Version: 2.0
Excel Version: 365
Post by hankler »
I'm having the same issue, can anyone explain how to fix this please.
hankler
Version: 2.0
Excel Version: 365
Post by hankler »
Never mind, i figured it out, i just created a new connection to PAW instead of TM1 and it worked.
Thanks to all
