What does 'Drill object was successfully built but did not return a valid handle' mean?
Which part of the drill through is causing this error? I have used Relational Drill Through
Drill Through - Valid Handle
kangkc
- Version: 2.x
- Excel Version: 36x
Re: Drill Through - Valid Handle
Check whether you have done these:
1. Create a drill through process xxxx (the actual TI process will be named as }Drill_xxxx, and can only view when you turn on View control objects)
2. Create a drill through assignment rule and relate the process defined to the rule as in xxxx (and not }Drill_xxxx)
