TM1 Web View value is different Architect View
aboyzhou
Post by aboyzhou »
Hi Experts,
I confused that why the same view display different result as below:
My TM1 version is 10.2.2 and FP7
display correct value by webpage
display mistake value by Architect
aboyzhou
Re: TM1 Web View value is different Architect View
Post by aboyzhou »
Can anybody help me ?
I have re-installed TM1 application, but the problem still on.
:cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry:
From the screenshots, the dimensions and elements look the same, however, you will notice that cube view has white cells i.e. open for input and the cube view has greyed cells-are you sure that you are looking at the same cube and all intersections.
The only other thing I can suggest is to break both views down to leaf elements on all dimensions to confirm that at a N: level, numbers agree then work from there.
BR, George.
