Private Views in Contributer
akbiswal
OLAP Product: Cognos
Version: Cognos
Excel Version: ms office 2007
Post by akbiswal »
I am a new to cognos TM1 application. My question is to create a private view in Cognos TM1 contributer. Presently I can see the default view.
Thanks in Advance
Ashish
Re: Private Views in Contributer
Contributor (or a.k.a. or rebranded to TM1 Application Web) only supports public views and subsets.
mvaspal
OLAP Product: tm1
Version: 10 2 2 - 2.0.5
Post by mvaspal »
This is not 100% true, only 99% :)
If you change the default views by reorganizing the layout, and close down the Contributorwindow, in the background the last state of the view is saved as a private view and next time you open up the node, your last state will be opened.
But otherwise you really cannot save down private views from there
akbiswal
Version: Cognos
Post by akbiswal »
We have a default view.
But I want to show a private view in contributor.
Is it possible. ? Or I have to convert private view into default view.?
Emixam
Post by Emixam »
mvaspal wrote: Thu Jul 20, 2017 2:20 pm If you change the default views by reorganizing the layout, and close down the Contributorwindow, in the background the last state of the view is saved as a private view and next time you open up the node, your last state will be opened.
I have an issue with one of my client. Whenever user change the layout of the view (i.e., swap rows and columns) in TM1 Applications Web (Contributors) and close the application, the next time they will re-open the same view it still show the Default view.
Looks like the applications doesn't recognize the last state of the view. Is there a parameter to change or a value in a Control Cube I need to change ? Do I need to change something in Performance Modeler ?
We are using PA 2.0.6 Local.
Thank you and have a nice day !
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
1. Are you sure that the user opens the same workflow node?
2. Check the DATE\namespace\User\YouCube}vues\View_Name_With_GUID_and_node_name.vue. Does it exist? If so, is it THAT view made by user (you can open in in Architect or just analyse using notepad)?
PS thats MY signature! ;)
Emixam
Post by Emixam »
Elessar wrote: Mon Jun 15, 2020 7:09 pm 1. Are you sure that the user opens the same workflow node?
Yes, I did the following:
1. Open my TM1 Application using a 'test account'.
2. Click on a specific node in the workflow
3. Take Ownership and change the view.
At this point, I see nothing under \Data\AD\test account\CubeName}vues
However, I see a random newly created folder in \Data\AD\test account\Sandbox as well as a new file named sandbox.namemap in that same folder.
4. I close everything, reopen the same application/view by using the same workflow node and I still see the default view...
When I look at some user, sometime the file is created but they still only see the default view :( It used to work but we did a lot of modification, changed a lot of things in the Web Applications (change view layout, change view name, etc...) and after we redeploy last week, user are always seeing the default view no matter what..
Elessar wrote: Mon Jun 15, 2020 7:09 pm PS thats MY signature! ;)
Hahah that's funny !!
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
What browser do you use? Have you tried another? There was an error with IE years ago: the views didn't save with it.
What do you mean by "change the view"? If you just select filters, it's not a trigger to save the view. You should drag dimensions between rows/columns/filters
Just try upgrade to 2.0.9.1. The 2.0.6-2.0.9.1 fixlist is huge. There is a chance that your case is an issue and it is already fixed.
Emixam
Post by Emixam »
Elessar wrote: Tue Jun 16, 2020 6:07 am What browser do you use? Have you tried another? There was an error with IE years ago: the views didn't save with it.
They are using Internet Explorer but I test with Google Chrome and i have the same result.
Elessar wrote: Tue Jun 16, 2020 6:07 am What do you mean by "change the view"? If you just select filters, it's not a trigger to save the view. You should drag dimensions between rows/columns/filters
Sorry if it was not clear.. Yes swap columns with rows and move columns into context, etc...
Elessar wrote: Tue Jun 16, 2020 6:07 am Just try upgrade to 2.0.9.1. The 2.0.6-2.0.9.1 fixlist is huge. There is a chance that your case is an issue and it is already fixed.
I will suggest my client to upgrade to 2.0.9.1. The weird part is now it's working in PROD but it's not working in Dev..
Thanks a lot for your answers Elassar, it's really appreciated !
Emixam
Post by Emixam »
A little update if someone have the same issue.
An upgrade from 2.0.6 to 2.0.9.1 fixed the issue.
Thanks again Elassar.
