Format zeros as blank in planning analytics
BigG
OLAP Product: IBMPA
Version: PA 2.0 Cloud
Post by BigG »
Hi there, does anyone know how to make a zero value blank in PA. The methods in TM1 have caused an issue with PAW (returns an error for zero) and PAX (returns #Value from any excel calcs referencing the blank). Obviously still works in architect when developing.
My fix is forcing a zero, which I can live with, But just checking I am not missing another option. This one works but does not display as blank:
c:#,##0_);(#,##0);0
I have tried # and "", and _) for the zero values, but 0 is the one that works (probably because out of all those options it is the only one which is an actual number)
BTW - I found leaving the zero area of format blank worked for PAX but not PAW (get error on zero cells)
GG
Re: Format zeros as blank in planning analytics
Leaving blank for zero SHOULD work and if it doesn't it's a bug.
E.g. 0;-0;
That's the universally standard and accepted method to specify blank for zero or null.
BigG
OLAP Product: IBMPA
Post by BigG »
thanks lotsaram
Probably a bug but IBM support were not that interested, maybe it will be fixed, but it is an issue at the moment.
GG
ellissj3
Version: 9.0 - 10.2
Post by ellissj3 »
I raised this with IBM. They mentioned that the number formatting must be on "0.00" for this to work. They mentioned it would be fixed in future releases.
I found this on 10.2.2 FP3.
HTH
