I have 5 Elements A, B, C, D, E ( all are of level 4-5..... they have hierarchy of their own).... Dimension Name : PRODUCT
C is Child of B
I am looking for an MDX Expression to display A, B, C and all only Leaf level Elements of C
Need Help
MDX Expression needed
Re: MDX Expression needed
{[PRODUCT].[A]} + {[PRODUCT].[B]} + {[PRODUCT].[C]} + {TM1FilterByLevel( Descendants([PRODUCT].[C]), 0)}Best regards,
- gtonkin
Apologies OP for high-jacking the thread to some degree but was intrigued with Wim's notation using the plus sign to "add" elements to the set.
I have always just done:
but like the plus signs for readability-Thanks Wim.
{[PRODUCT].[A], [PRODUCT].[B], [PRODUCT].[C], TM1FilterByLevel( Descendants([PRODUCT].[C]), 0)}
In MDX "+" is shorthand for UNIONgtonkin wrote:Apologies OP for higj-jacking the thread to some degree but was intrigued with Wim's notation using the plus sign to "add" elements to the set.
I have always just done:but like the plus signs for readability-Thanks Wim.Code: Select all
e.g.
{set1} + {set2}
{UNION( {set1}, {set2} )}
A union will automatically remove duplicates from the sets, whereas the comma operator simply concatenates the sets together (without removing duplicates). You can show this pretty simply by comparing
{ {set1}, {set1} }
vs.
{ {set1} + {set1} }
- gtonkin
Thanks for the clarification Lotsa-will keep that in mind.
Indeed, we have UNION( ), we have a comma and we have the + operator.
They differ when it comes to duplicate elements in the selection.
SBK88
- Version: 9.5.2
- Excel Version: 2013
Yes UNION worked for me......
Created 2 separate expressions then used UNION and it worked.
Thanks to all of u
Thanks to all of u
{[PRODUCT].[A]} + {[PRODUCT].[B]} + {[PRODUCT].[C]} + {TM1FilterByLevel( Descendants([PRODUCT].[B^C]), 0)}
Yeon
