I have seen docs suggesting that the advanced rules editor is no longer supported:-
http://www-01.ibm.com/support/docview.w ... wg21661245
However this would suggest that it is since the editor choice parameter is still listed:-
https://www.ibm.com/support/knowledgece ... ifile.html
Anyone know for sure?
Advanced rules editor
Re: Advanced rules editor
Supported and available are two entirely different things. IBM has a history of stopping support for a feature, yet leaving it in the product for a while. Dropping support just means you shouldn't count on it being available in the future.
Edward Stuart
- Version: All
- Excel Version: All
The Design and Develop models course with Architect - Planning Analytics/ 10.2 use examples with the Advanced Rules editor but also include a statement that the advanced rules editor is only supported to 10.1.1
AmbPin
- Version: 9.5.2
- Excel Version: 2007-10
Couldn't agree more, to put it politely I don't think the base knows what the apex is doing sometimes at IBMtomok wrote:Supported and available are two entirely different things. IBM has a history of stopping support for a feature, yet leaving it in the product for a while. Dropping support just means you shouldn't count on it being available in the future.
I don't have a long and robust history of standing in IBM's defence but really, they aren't doing anything wrong here.AmbPin wrote:Couldn't agree more, to put it politely I don't think the base knows what the apex is doing sometimes at IBMtomok wrote:Supported and available are two entirely different things. IBM has a history of stopping support for a feature, yet leaving it in the product for a while. Dropping support just means you shouldn't count on it being available in the future.
Depreciating a feature, which is to say still offering it but saying "Start phasing out your use of it, because some day in the future it will probably go away" is far and away better than just yanking a feature out of a product with a middle finger extended toward the customer. (See also, the Microsoft Office and Windows development teams since Office 2007 and Windows 8 respectively.)
IBM doesn't want to support or develop the A.R.E. probably because it's an evolutionary dead end. Could it be made better? Sure. Could it be made into a pretty decent tool with enough development work by the right people? Most likely. But it's .Net-based which effectively means Windows only. And I think IBM is looking through the prism of a cross-platform future. Devoting the amount of time and effort needed to beef up a single platform component probably isn't part of that.
So essentially they're saying "If it works for you, great. But we're not developing it any further so if it breaks, it breaks. We won't be taking support tickets on it. Please find another way of doing it." It's far better than just saying "The feature's been taken out without any advance notice, screw you all" as Redmond is wont to do these days. (With the notable exception of the SQL Server team, and maybe the .Net one as well.)
Indeed, that's what I use as well, with the TM1 syntax language.PavoGa wrote:Notepad++
Latest addition to my routines in TM1 Architect / Perspectives: I use the free Autohotkey tool to launch certain actions based on a shortcut, like Win key-q.
This shortcut copies the TI code in the selected Advanced tab (by sending Tab twice) and then ctrl-c.
Then it looks for a Notepad++ instance, if not found a new instance is created.
Then we paste the clipboard.
I remove the lines with the Generated Statements.
I activate the TM1 language.
And as the first line I insert the name of the Turbo Integrator window from which I copied.
Another shortcut (Win-z) can then do the inverse: copy code from Notepad++ to the given TI process, taking into account again the Generated Statements.
Last step in this fully automatic process is putting the cursor at the start of the first line of code.
From time to time this script has a glitch but doing it twice always solves it
I extended it to the Rules editor window as well.
I assume that more fancy solutions exist but this works fine for me
- PavoGa
- Excel Version: 2013 PAW
Cool stuff!!! I only use the TM1 syntax language and keep the files in a separate source code folder. To make sure I understand, you have it integrated with the TI editor in Architect? That is pretty cool. What I do is use a single text file with the sections delimited like:Indeed, that's what I use as well, with the TM1 syntax language.
Latest addition in the "toolkit": I use Autohotkey to launch certain actions based on a shortcut, like Win key-q.
I active the TM1 language.
Last step is to position in this fully automatic process is putting the cursor at the start of the first line of code.
I assume that more fancy solutions can exist but this works fine for me
###comments, blah for PROLOG
code
#_________________________ METADATA
any code
#_________________________ DATA
any code
#_________________________ EPILOG
any code
But I really like your toolkit idea.
Ty
Cleveland, TN
Cleveland, TN
Integrated in the sense of, Win-q copies the code in the tab to a Notepad++ window with TM1 syntax activated.PavoGa wrote:To make sure I understand, you have it integrated with the TI editor in Architect? That is pretty cool.
Win-z copies back from Notepad++ to the TI editor.
Of course, one should be cautious that the same TI advanced tab is still active after the changes in Notepad++ and so on, but in general this works fine.
