TM1 10.2.2 Fix Pack 7 delayed
jcr55
- Version: 9.5.2 FP2
- Excel Version: Excel 2007
I was originally told by our IBM account rep that Fix Pack 7 would be released March 29th.
But now he says the new target date is Monday April 3rd.
... if anyone is interested ...
Re: TM1 10.2.2 Fix Pack 7 delayed
I am. That's supposed to be the one that has the "You don't need to waste time fluffing around with gorramn SSL certificates that should have been replaced 2 or 3 years ago" version. It was expected in Q1 of 2017 which from my perspective finishes in just over 16 hours. I had been occasionally thinking about this in the last couple of weeks.jcr55 wrote:I was originally told by our IBM account rep that Fix Pack 7 would be released March 29th.
Darkhorse
- Excel Version: 2003 2007 2010 2013
I found the interim fix patch 6 seemed to fix the SSL issue automatically
Paul Segal
- Version: TM1 11 and up
Fix pack 7 appears to be available now: http://www-01.ibm.com/support/docview.w ... wg24043147
Paul
- gtonkin
Hi Paul, your link seems to be for Cognos BI - TM1 10.2.2 FP7 does not look to be available yet but fixes are at http://www-01.ibm.com/support/docview.w ... wg27041360
Paul Segal
Oops, wrong link. But! http://www-01.ibm.com/support/docview.w ... wg24043388
Paul
- gtonkin
Thanks Paul-downloading now.
jcr55
Thank you Paul - downloading now
Bakkone
- Excel Version: 2013
Any issues with upgrading or do I just hit next like I normally do?
Sighurd
- Version: 10.2.2fp6
Does it actually address the issue that Alan mentioned? I don't see it in "Issues corrected in IBM Cognos TM1 10.2.2 FP7.", but may be they don't consider it an issue...
Edward Stuart
- Version: All
- Excel Version: All
I've installed to my local machine and can confirm that the Certificates that come with Fix Pack 7 are all dated 25th March 2017
The Certificate Authority defaults to:
C:\Program Files\ibm\cognos\tm1_64\bin\ssl\tm1ca_v2.pem
(But I have various installs over the lifetime of this laptop)
Changing the certificate to:
C:\Program Files\ibm\cognos\tm1_64\bin64\ssl\applixca.pem
Revealed the sample models
In Cognos Configuration the "TM1 Admin Server", TM1 Admin Server Certificate Version is set to 1
yingchai
Does anyone encountered any bugs in FP7?
