Set ODBO Datasource in Prolog
- PowerDim
- Version: PAL 2x
- Excel Version: Excel 2019
Hello everyone!
IBM Cognos TM1 Build Number: 10.2.20603.106
OS: Windows Server 2012 R2 Standart
We have several servers. On each server (OS - the same) there are several different Cognos models (TM1 Version - the same).
There is a need to transfer data from one server to another and from another model.
The customer insists on using ODBO-connection.
When loading with ODBO, we need to use the MDX-Query.
For example.
Source1:
ODBO Provider - IBM Cognos TM1 OLE DB MD Provider
ODBO Datasource - ServerName1
ODBO Catalog - ModelName1
ODBO UserID - User1
ODBO Password - Password1
MDXQuery1
Source2:
ODBO Datasource - ServerName2
ODBO UserID - User1
MDXQuery1
Target:
ServerName3
ModelName3
There is a server ServerName3 and model ModelName3.
We need to transfer data from ServerName1 and ModelName1.
We write the TI process and use the ODBO-connection as the source.
We select MDX-Query and write a query.
At some point, the customer changes the server (the model in this example is not necessary).
Now, as a source, we need to use ServerName2.
We have many TI-processes, like this.
Therefore, we would like to change the name of the server in one place so that the name of the server changes to the new one in all TI-processes at once.
Based on the situation above, the question is:
Is it possible to set the ODBO Datasource in the Prolog of the TI-Process?
After a short investigation, it became clear that:
- I did not find a special local variable for the possibility to set ODBO Datasource;
- You can set a subset (DataSourceODBOHierarchyName) and a cube (DataSourceODBOCubeName), but there is no separate local variable for MDX-Query (for example, it could be called DataSourceODBOQuery). This is another additional question;
# Local variable DatasourceQuery, as it seems to me, should not work here.
- You can set ODBO Catalog using the local variable DataSourceODBOCatalog.
This idea arose because for other sources for TI-processes, it is possible to set the types and source names in the Prolog tab.
For example, when we specify, as a source, the view of a cube, then we can use local variables in Prolog of TI-process.
For example.
DataSourceType = 'VIEW';
DatasourceNameForServer = sSrcCube;
DatasourceNameForClient = sSrcCube;
DatasourceCubeView = sView_Sub;
For information.
Link to local variables:
https://www.ibm.com/support/knowledgece ... les_N80019
P.S.
There was an attempt to write Prolog, but it ended, as expected, unsuccessfully:
DataSourceType = 'OLEDBOLAP';
DataSourceODBOProvider = 'IBM Cognos TM1 OLE DB MD Provider';
DataSourceODBOLocation = '';
DatasourceNameForServer = 'ServerName2';
DatasourceNameForClient = 'ServerName2';
DataSourceODBOCatalog = 'ModelName1';
DatasourceUsername = 'User1';
DatasourcePassword = 'Password1';
DatasourceQuery = 'SELECT <...> ';
In the end, there was an error:
Error: Prolog procedure line (0): Unable to open data source 'ServerName2'.
In this case, if you use the standard functionality, everything works (that is, ServerName2 and ModelName1 are available).
The alternative - to do replace in files * .pro and restart the model.
Thank you!
Dmitry
For example.
Source1:
ODBO UserID - User1
MDXQuery1
Source2:
ODBO UserID - User1
MDXQuery1
Target:
ServerName3
ModelName3
For example.
For information.
P.S.
Thank you!
Dmitry
Dmitry
Dmitry
Re: Set ODBO Datasource in Prolog
Welcome on board with your first post here.
Not sure I understand what is going on, but this works fine for me:
In fact, I started generating the process, and then outside the generated statements I added my own coding.
If I change the TM1 model name to something non-existing, the process stops which is correct).
Wim
DataSourceNameForServer = 'THE_NAME_OF_MY_PC';
DataSourceODBOCatalog = 'THE_TM1_MODEL_NAME';
DataSourceQuery = '"WITH SET [General_Years Set] AS
''{ FILTER( { [General_Years].MEMBERS }, ISLEAF( [General_Years].CURRENTMEMBER ) ) }''
SET [General_Months Set] AS ''
{ FILTER( { [General_Months].MEMBERS }, ISLEAF( [General_Months].CURRENTMEMBER ) ) }''
SET [CPI_Geldwaarde Set] AS
''{ FILTER( { [CPI_Geldwaarde].MEMBERS }, ISLEAF( [CPI_Geldwaarde].CURRENTMEMBER ) ) }''
SET [CPI_Measures Set] AS
''{ FILTER( { [CPI_Measures].MEMBERS }, ISLEAF( [CPI_Measures].CURRENTMEMBER ) ) }''
SELECT NON EMPTY { [General_Years Set] * [General_Months Set] * [CPI_Geldwaarde Set] * [CPI_Measures Set] } ON COLUMNS FROM [CPI] "';
IF ( CUBEEXISTS('test') <> 0 );
CUBEDESTROY('test');
ENDIF;
ret_code=EXECUTEPROCESS('_test ODBO 2_General_Years');
if (ret_code = ProcessExitSeriousError() );
ProcessError();
endif;
ret_code=EXECUTEPROCESS('_test ODBO 2_General_Months');
ProcessError();
endif;
ret_code=EXECUTEPROCESS('_test ODBO 2_CPI_Geldwaarde');
ProcessError();
endif;
ret_code=EXECUTEPROCESS('_test ODBO 2_CPI_Measures');
ProcessError();
endif;
CUBECREATE('test','General_Years','General_Months','CPI_Geldwaarde','CPI_Measures');
OldCubeLogChanges = CUBEGETLOGCHANGES('test');
CUBESETLOGCHANGES('test', 0);
asciioutput( 'test.txt', DataSourceNameForServer );
asciioutput( 'test.txt', DataSourceODBOCatalog );
asciioutput( 'test.txt', DataSourceQuery );If I change the TM1 model name to something non-existing, the process stops which is correct).
Wim
- PowerDim
- Version: PAL 2x
Thank you, Wim, for the warm welcome!
Yes, you really did not quite understand what I asked about initially.
But you helped me A LOT in solving my problem.
Thank you!
When I put the values of local variables in a file (TextOutPut) during the standard functional is working (without using any overrides in the Prolog) I was able to understand, what it is necessary to write in the Prolog for the correct override of the ODBO-connection.
TI-Processes will not work correctly if the source server has been changed. We would have to update each process manually... This is extremely inconvenient and long. So we created one more parameter in our cube with system parameters, in which we store the value of the source server (it is not some new approach, just for information
Now in our updated process, we refer to this parameter (CellGetS) and redefine the source in the Prolog using the same scheme as for the other types of loading (for example, DataSourceType = 'VIEW';).
As a result, we got the working code of the following kind, which solved our problem:
This approach allows you to make the use of ODBO-connection more flexible and independent of changes to the original connection parameters.
We can change the source server for all processes at once, which reference the cube with system parameters.
Perhaps someone will come in handy
P.S.
As we can see, the problem was that the required values of local variables are not specified in the IBM knowledge center, for example:
DataSourceType = 'ODBOMDXQUERY'
and
DataSourceODBOProvider = 'TM1OLAP';
And, unfortunately, the case of using these local variables together is not described anywhere, in order to correctly redefine the Prolog.
Or I did not find.
Anyway, now the information is here
Dmitry
Thank you!
DataSourceType = 'ODBOMDXQUERY';
DatasourceNameForServer = CellGetS ('System_Parameters', 'SP_01', 'String');
DataSourceODBOCatalog = CellGetS ('System_Parameters', 'SP_02', 'String');
DatasourceUsername = 'UserName1';
DatasourceQuery = 'SELECT <...query...>';We can change the source server for all processes at once, which reference the cube with system parameters.
P.S.
and
Or I did not find.
Dmitry
Dmitry
Dmitry
- PowerDim
- Version: PAL 2x
One more thing
For some reason, security specialists can prohibit storing the login and password openly and side by side in the TI-process (most likely it's a technical user with administrator rights).
In this case, you can do the following:
In Prolog you do not need to use local variables, which will override the user's login and password, with which we want to connect to another server.
When the TI-process starts, it will use those servers and models, that we specify in Prolog, and the user's login and password will be used based on the information from the first tab, where we first set up the ODBO-connection, when creating the TI-process.
It looks like this:
Dmitry
It looks like this:
#---------First Tab: Start---------#
<...Settings of ODBO-connection..>
ODBO UserID - UserName1
ODBO Password - ********
#---------First Tab: End-----------#
#---------Prolog: Start---------#
#---You can delete it-------#
# DatasourceUsername = 'UserName1';
# DatasourcePassword = 'Password1';
#---------Prolog: End-----------#Best regards,
Dmitry
Dmitry
Dmitry
That's true, and it's the reason why I only mentioned the local variables you would overwrite.
If you start from a working process with the correct data source type and credentials, things are easier.
- jim wood
- Version: PA 2.0.7
Hey Wim,
I'm having a play around with ODBO and I've tried passing a parameter to the code as follows:
The process saved but when I ran it to do a test export it ran for all projects rather than the one specified as the parameter. Here is my prolog section in total:
Jim.
DataSourceQuery=
'"WITH
SET [Capital - Version Set] AS
'' { [OnBoarding - Version].[Forecast] } ''
SET Capital - Projects] AS
'' { [OnBoarding - Projects].['|pProject|'] } ''
SET [Capital - Attribute Measures] AS
'' { FILTER( { [OnBoarding - Attribute Measures].MEMBERS }, ISLEAF( [OnBoarding - Attribute Measures].CURRENTMEMBER ) ) }''
SELECT NON EMPTY { [Capital - Version Set] * [Capital - Projects Set] * [Capital - Attribute Measures Set] } ON COLUMNS FROM [OnBoarding Attributes] "';
DataSourceType='OLEDBOLAP';
DataSourceNameForServer='*********.PACORP.PANYNJ.GOV';
DataSourceODBOCatalog = 'DEV_Project_OnBoarding_Financials';
DataSourceODBOConnectionString='CAMNamespace=Active Directory';
DataSourceUserName='******';
DataSourcePassword='*********';
DataSourceQuery=
'"WITH
Jim.
- PowerDim
- Version: PAL 2x
Hello, Jim!
Perhaps, I can help in solving your problem.
To specify the values that are passed from the parameters, you have to use the following syntax: [Dimension].[?ParameterName?]
For example:
Dmitry
For example:
DatasourceQuery = '
SELECT {TM1FILTERBYLEVEL( {TM1SUBSETALL( [Period] )}, 0)} ON COLUMNS,
Non empty
{[Measure_Test].[MSR_001], [Measure_Test].[MSR_002]}
* {TM1FILTERBYLEVEL( {TM1DRILLDOWNMEMBER( {[Entity].[?pEntity_Hierarchy?]}, ALL, RECURSIVE )}, 1)} ON ROWS
FROM [Cube_Test]
WHERE ( [Scentype].[?pScentype?], [Year].[?pYear?], [Version].[?pVersion?], [Scenario].[?pScenario?] , [Value].[NValue])
Dmitry
Dmitry
Dmitry
- jim wood
- Version: PA 2.0.7
Ah ok, so it behaves in the same way as passing a parameter to a query in the data source tab. Nice and thanks,
Jim.
Jim.
- jim wood
- Version: PA 2.0.7
So it looks like the query I've specified is not running in the Data Tab. It is still running the original query. I can only guess that I'm missing something from data source overrides:
I have exported the parameters as Wim suggested above and they (including the query) are coming out as specified in the prolog. I'm stumped as to why this is happening. Any ideas guys?
Jim.
DataSourceType='ODBOMDXQUERY';
DataSourceODBOProvider='TM1OLAP';
DataSourceODBOLocation='';
DataSourceNameForServer='**************';
DataSourceODBOCatalog = '*************';
DataSourceUserName='*************';
DataSourcePassword='*************';
DataSourceQuery=
'"WITH
''{ [OnBoarding - Version].[Forecast] }''
SET [Capital - Projects Set] AS
''{ [OnBoarding - Projects].[?pProject?] }''
SET [Capital - Attribute Measures Set] AS
''{ FILTER( { [OnBoarding - Attribute Measures].MEMBERS }, ISLEAF( [OnBoarding - Attribute Measures].CURRENTMEMBER ) ) }''
SELECT NON EMPTY {
} ON COLUMNS FROM [OnBoarding Attributes] "';Thanks,
Jim.
- jim wood
- Version: PA 2.0.7
I tried to simplify the query:
But still not working
DatasourceQuery =
'SELECT NON EMPTY
{ [OnBoarding - Projects].[?pProject?] } * { [OnBoarding - Version].[Forecast] } * { TM1SUBSETALL( [OnBoarding - Attribute Measures] ) }
ON COLUMNS
FROM [OnBoarding Attributes]';Struggling through the quagmire of life to reach the other side of who knows where.
- jim wood
- Version: PA 2.0.7
Taxi for me. Sussed it. I had my override code below the query generated code in the prolog. Thanks for all your help PowerDim,
Jim.
Jim.
