I am trying to write a TI process to copy from a planning cube to a reporting Cube. Both are large cubes and am looking for best ways for performance.
we are using 10.2.2.
Paul.
Copy Large Cube to Cube advice
LutherPaul
- gtonkin
Re: Copy Large Cube to Cube advice
HI Paul,
You probably need to give some more information e.g.
-Have you looked up Batrch Update vs Bulk Load? Would users need to access whilst refreshing?
-Frequency of copying
-Once off all data then incremental or all everytime
-Some idea in terms of structure i.e. are you taking ALL N across all dimensions, Are you reading from C levels etc. etc.
-Skip options considered/applicable e.g. Consolidations, Calcs, Zeroes
-String data and suppression gotchas
-Would rules work instead?
-What thought have you given to Metadata-are dimensions cloned are different for the reporting requirements?
I am sure there are many more considerations but please let us have your thoughts so that everyone can respond accordingly.
LutherPaul
Thanks gtonkin for the reply. sorry, took a longer to reply on this.
I have another question. The view built to copy data uses MTQ to retrieve, but the copy is single threaded (I think it's writing a row each time.) Is there multi-threaded copy?
We are on TM1 10.2.2 FP4.
Answers are below.
-Have you looked up Batrch Update vs Bulk Load? Would users need to access whilst refreshing? --> bulkload was taking longer than regular TI load and got a ticket created to IBM. Never tried Batch update
-Frequency of copying --> Daily
-Once off all data then incremental or all everytime --> Plan data can change anytime or all time.
-Some idea in terms of structure i.e. are you taking ALL N across all dimensions, Are you reading from C levels etc. etc. --> Reading ALL N across all dimensions - leaf level elements.
-Skip options considered/applicable e.g. Consolidations, Calcs, Zeroes --> Skipping Zeros and reading all rule calculated cells.
-String data and suppression gotchas --> none
-Would rules work instead? --> No
-What thought have you given to Metadata-are dimensions cloned are different for the reporting requirements? --> Dimensions for reporting cube are different from planing.
Paul.
Answers are below.
Paul.
- Steve Rowe
You need to think about which aspect of performance you want to maximise. Usually people think that they want to make things fast but actually what they mean is "The copy process locks the environment so I want to make it run fast".
So really you probably want to minimise the length of the lock.
The easiest way of doing this to do the export to a flat file and then do the read from the file with no metadata maintenance.
I find it a bit strange that no one has mentioned parallelising the load by breaking the view into multiple slices along one dimension. In 10.2.2 with parallel interaction this is an easy and foolproof way to reduce end to end processing time. I wouldn't ever consider BulkLoadMode, the speedup multiple possible is very limited due to the single threaded nature and it comes with disadvantages in terms of locking out logins which very much outweigh any benefits.LutherPaul wrote:Hi All,
Paul.
- mattgoff
- Version: 10.2.2.6
- Excel Version: O365
Is this any faster than performance under 10.2.2 FP6 which enabled MTQ view generation via TI?I find it a bit strange that no one has mentioned parallelising the load by breaking the view into multiple slices along one dimension. In 10.2.2 with parallel interaction this is an easy and foolproof way to reduce end to end processing time.
I have tried to get BulkLoadMode to work many times with zero success. Could be I'm doing something wrong, but I had nothing but problems with locking out users and little to n performance improvement (and a lot of crashes, granted this was years ago).I wouldn't ever consider BulkLoadMode, the speedup multiple possible is very limited due to the single threaded nature and it comes with disadvantages in terms of locking out logins which very much outweigh any benefits.
Matt
