Tip of the Day - Ctrl+N and MDX
In the current perspectives subset editor if you select elements and do ctrl+n and then ctrl+v you get the MDX references for the elements selected.
Can come in pretty handy.
You can thank my bad tping for this tip!
Re: Tip of the Day - Ctrl+N and MDX
Thanks!
Indeed, we can reference elements in a dimension like that.
{[dimension].[element]}
The part in the middle is the result of ctrl-n, ctrl-v.
I have seen people using TM1SubsetAll, Hierarchize, TM1FilterByLevel, TM1FilterByPattern on the exact same element string without wildcards, just to end up with the same 1 element :shock: :D
rafaewolie
OLAP Product: IBM Cognos TM1
Version: TM1 PA 2.0
Excel Version: Excel 2013
Post by rafaewolie »
Very Usefull, thanks for the tip
