I was told to test the ODBCOutput by doing ASCIIOutput first...So this is my understanding on how to create an ASCIIOutput File base on th PDF included in the installation.
When I pick a specific TM1 Cube View, do I have to define everything as String? or do I define the column containing the values as Numeric. If so, I can't to make it work, I can only make the the value field work if I define it as a String and contents are all defined as OTHERS. I can't make the value as Data.
As expected when I opened the ASCII file, the value is not formatted correctly. How will I know if this will even go in my datasource if all variables are string?
ASCII Output & TextOutput
appleglaze28
- Excel Version: 2003
Re: ASCII Output & TextOutput
All of the arguments that you pass to an AsciiOutput command have to be strings. If a value is numeric (which is typically the case with the Value variable of a cube view, assuming that you aren't storing strings in the cube), you have to convert it first.appleglaze28 wrote:I was told to test the ODBCOutput by doing ASCIIOutput first...So this is my understanding on how to create an ASCIIOutput File base on th PDF included in the installation.
Use either the Str() rules function, or the NumberToString (or NumberToStringEx) TI functions to convert the Value field, which you can then leave as a Numeric type.
I generally define all variables as having a content of "Other" (or "Ignore") because I never use TI-generated code; I write it all myself. The other content values are only useful (for certain values of "useful") if you're using the Maps tab.
appleglaze28
So base on what you say its not necessary to test ASCIIOutput on the cube that you want to load to a database like what David recommended in my previous post?
http://forums.olapforums.com/viewtopic.php?f=3&t=932
I just need to make sure the my ODBCOutput statement contains single quote for all string elements and the numeric will be as is?
You're talking about two completely different things. In this thread you were asking why your AsciiOutput command wasn't working. The reason for that, as I said, is that you have to ensure that all of the arguments to the AsciiOutput function are strings.appleglaze28 wrote:So base on what you say its not necessary to test ASCIIOutput on the cube that you want to load to a database like what David recommended in my previous post?
If you have a 3 dimensional cube where Dim1, Dim2 and Dim3 are defined as String with a content type of Other, and Value is defined as Numeric with a content type of other, then this will work:
AsciiOutput ( 'OutputFile.txt', Dim1, Dim2, Dim3, NumberToString (Value));Code: Select all
AsciiOutput ( 'OutputFile.txt', Dim1, Dim2, Dim3, Value);However David's not recommending that you output the values from the cube view anyway; he's recommending that you output the SQLQuery that you intend to feed to the ODBCOutput to ensure that you have the syntax correct. And the SQLQuery argument has to be a string, which means that you need to convert any numeric values to a string at some point anyway (unless you bring the value in as a string in the first place) because unlike VB/A, TI won't do an implicit data type conversion.
