MDX: Filter Parents but sort their Children
Ptec
Version: 10.2.2.0
Post by Ptec »
Hey there,
I have a "Problem" Im working on for 2 days now but couldn't find a solution till now.
I have a Dimension with a Top Node, 2 Parent Elements with several Childs. All Elements have a numeric Attribute like 10,11,13...
We now need the Children to be sorted ascending to their Attributes BUT the Children shouldnt be Drilled Down/Expanded in the Subset View.
So in short hand:
1. Filter Level 1 and 2 Elements (Working)
2. Sort these Elements depending on their "Sort" Attribute Ascending (Working)
3. Sort the Child Elements of these Parents depending on their "Sort" Attribute Ascending (Not working)
I provide here an Image so you better understand my needs and hopefully a MDX genius can help me out with this!
Target Subset Filtering and Order.png (55.25 KiB) Viewed 5282 times
If this is not achievable with an MDX Statement maybe a TI Process will do it?
Thanks!
Re: MDX: Filter Parents but sort their Children
As an easy approach why not concatenate the parent and children sorts... so 11 could be a consolidation and under it 11.1, 11.2 etc.
Ptec
Version: 10.2.2.0
Post by Ptec »
Does it make a difference because how could I sort the children? The "ORDER" MDX Command just uses the "Filtered" Elements which are the parents, so the Ordering takes no effect on the children...
I tought of using a Subset Drilled down all Elements so I get the correct Attribute Order. That works already.
Now i wanted to use this Subset in TI to Create another Subset with the above MDX Statement (my first post). BUT I think it's not possible to use a Subset with the "TM1SUBSETALL" command right?
ardi
OLAP Product: tm1, cognos bi
Post by ardi »
Ptec wrote:Does it make a difference because how could I sort the children? The "ORDER" MDX Command just uses the "Filtered" Elements which are the parents, so the Ordering takes no effect on the children...
If you concatenate the Sort attribute then you can achieve what you want.
{ORDER ( {TM1SUBSETALL( [dim_Kunden] )} , [dim_Kunden].[Sort], ASC)}
By concatenating the Parent Sort with Children Sort Order you will maintain the "Hierarchy Sort" of your dimension and also within each hierarchy, you will apply your desired sort for the children
Ardian Alikaj
