Hello All,
I'm currently experiencing a strange issue when using an excel report (linked to TM1) which has been published as an application in TM1 so that it is viewed using TM1 Web. The report has a line chart too.
I have a drop down list of companies which the user can select from. This drives some DBRW formulae to retrieve data for the company select which in turn drives the chart. One thing I have noted is that the legend in the chart (which picks up the company) does not update when switching between companies selected from the drop down list.
I thought that it could be the drop down, so i changed it to a SUBNM but this doesn'tt work either. The data is pulling in however it is the legend which is not changing.
The report works in Excel, but not when published to web.
Any clues ?
Ajay
