using Cognos 10.1.1. Every time I create a cube from TurboIntegrator I manually right click on cube and select Properties option, then I select a dimension for "Measure Dimension" setting. I have to assign measure dimension because of Cognos BI requirement.
My idea is to just add some TI function to the TI create cube process. Is there a TurboIntegrator function to assign Measure Dimension cube property to cube?
[SOLVED] What is TurboIntegrator function to assign Measure Dimension cube property to cube?
- Version: 10.1.1
- Excel Version: -
- OLAP Product: IBM Cognos BI
- Version: 10.2
- Excel Version: Excel 2010
Re: What is TurboIntegrator function to assign Measure Dimension cube property to cube?
why cant you assign value in }CubeProperties using cellputs('Dimension name', '}CubeProperties','Cube name','Measures Dimesnion') in your TI code?
- Version: 10.1.1
- Excel Version: -
In Epilog of create cube TI process I added code:
Where: 'Dimension_name' is measure dimension name and 'Cube_name' is cube name.
Thanks for help. Problem solved.
P.S.It totally flip my mind that TM1 settings are also stored in cubes.
CellPutS('Dimension_name', '}CubeProperties', 'Cube_name', 'MEASURES_DIMENSION');
Re: [SOLVED] What is TurboIntegrator function to assign Measure Dimension cube property to cube?
That's pretty much the only place TM1 has to store content. Sometimes IBM deigns to document what is where.
