TM1 Perspectives on High Definition (Retina Screens)
4rtem
Post by 4rtem »
Does anybody have such problems with TM1 Perspectives on Retina screen?
See the screenshot attached.
I have 10.2.2 FP4 installed and it looks that way :(
Screen Shot 2015-09-16 at 14.47.06.png (417.48 KiB) Viewed 8450 times
“The way to get started is to quit talking and begin doing.” - Walt Disney
Re: TM1 Perspectives on High Definition (Retina Screens)
Post by David Usherwood »
At least you could slice it to Excel or use the (deprecated but zoomable) In Spreadsheet Browser. Just wait till you need to write a TI :o
I have a Dell XPS15 with a 3200x1800 screen and decided very quickly to crank the resolution down to 1600 x 900 for most purposes.
Also note that Perspectives is not getting IBM's attention much as they want us all to go CAFE. Not that I've tried the latter at 3200x1800.
4rtem
Post by 4rtem »
I also solved the issue for myself decreasing resolution to 1900x1200.
But now I have the same issue with potential client.
CAFE still does not cover flexibility of Perspectives.
4rtem wrote:Does anybody have such problems with TM1 Perspectives on Retina screen?
Yes. I have suffered from this many times. It is a real pain on a high res screen. The only solution is to scale down to full HD 1920x1080, otherwise the perspectives icons render as tiny specks and the rows in the cube viewer grid overlap and the server explorer client is basically unusable.
captnknz
OLAP Product: Tm1
Version: 13.0
Post by captnknz »
It is possible to 'fix' this in Architect by going to tm1a.exe properties, compatibility settings, and selecting Override High DPI behaviour Scaling performed by System. Still looking into perspectives.
Kirk Bensemann
hari_cundi
Version: 9.5.2
Excel Version: 10
Post by hari_cundi »
Kirk,
Have you had any luck troubleshooting Perspectives?
My clients are experiencing the same resolution issues.
Hari
