compare data between dimension with data file in architect (check index)
myimyoona
OLAP Product: cognos TM1
Version: 10.2.0
Post by myimyoona »
Hi sir :)
I need to write code compare data between dimension with data file by ti process
example
-In dimension have data but i need to update attribute in dimension, I must load text file .csv into dimension and data must compare
if have data, compare data and update but data not have must insert to dimension
TrevorGoss
Version: 10.2.1.1
Excel Version: 14.0.6129.5000
Re: compare data between dimension with data file in architect (check index)
Post by TrevorGoss »
It may well be possible to do this without using the .dim data files.
The .dim data files wont tell you must, and I do not see how you can work out attributes from the .dim data file.
There are many TI functions that can help you here, ATTRS and all that.
What excatly is it you need to do, it was somewhat difficult to understand?
Thanks.
Trevor.
BariAbdul
Version: PAW 2.0.8
Excel Version: 2019
Post by BariAbdul »
example
First of all dimension doesn't hold data ,it is metadata.
It is not clear what exactly you are up to,But There is TI function Dimix to check for the element exists.Please describe in detail with the actual data what you are trying to achieve.
TrevorGoss
Version: 10.2.1.1
Indeed, this sounds like somthing that could be solved with a fairly straight forward TI as the compiled (if thats the right word) data files will be expressed fully in TM1 when TM1 is loaded, which would then allow you to use a TI, the data files are seperated and not always readable.
The only times I have gone into the data files is to change a time of a Chore (GMT bug) or to use a program without the API to go into the .cub files and get all the dimensions, which was not pretty.
myimyoona
Version: 10.2.0
Post by myimyoona »
result must that pic.
sorry for my question.
https://www.img.in.th/image/0g2
TrevorGoss
Version: 10.2.1.1
If possible, do you mind pasting the image in the forum? I cannot view the image at work, because of security.
That is quite alright!
Thanks.
Trevor.
