Write Feeders in rule with picklist
ChauBSD
Post by ChauBSD »
I have problem about write feeders. I have 2 cube contain and rule calculation
['GiaTriPhatSinh']=N:IF(DIMIX('SL_Times', ATTRS('SL_Times', !SL_Times, 'VN'))= DIMIX('SL_Times', DB('TS_CCDCHienTai',!TS_CCDCHienTai,!Version,!Level_CCDC,'ThangBatDau')),
DB('TS_CCDCHienTai',!TS_CCDCHienTai,!Version,!Level_CCDC,'NguyenGia'),STET
I have ThangBatDau type picklist. How should I write feeders????
Thanks you
Re: Write Feeders in rule with picklist
Hello
This type of rule is difficult to feed. If I understand what you mean because it isn't too clear.
I would suggest to feed from the same cube, from a different measure, to 'GiaTriPhatSinh', if possible.
