Hello
I am not sure if you guys are aware of this bug but occasionally, some of my feeders are not feeding cubes and to solve that problem, we need to comment out rules and then uncomment them, save and run. This will allow the feeders to kick and will allow the feeders to work.
What could be thhe issue and do we know of any long term or short term solutions to this?
Thank you
Feeder Issue
mithun.mistry11
- OLAP Product: tm1
- Version: 10.2
BariAbdul
- Version: PAW 2.0.8
- Excel Version: 2019
Re: Feeder Issue
Have you tried to unload and load cube?Is the same issue persists by unloading and loading cube back?
Gabor
- Version: [2.x ...] 11.x / PAL 2.1.13
- Excel Version: Excel 2016-2021-365
Re: Feeder Issue
I haven't seen any bug with feeding in version 10.2 so far.
On the other hand, there are a couple of circumstances, which could lead to the behaviour that you see, but driven by the way how feeding works.
Adding a leaf element to a dim, which is fed over a consolidation in that dim or using conditional feeding are just 2 examples.
It all depends on how your feeder rule is written. Also, assuming the feeder rule itself gives no room for improvement, there are several options to further optimize TM1, e.g. tm1s.cfg re-evaluation settings or TI based feeder re-processing.
