HI all
Recently due to some issue we have restored the server to previous date,before restoring i have taken the DB backup
and after restored the server i have put back again Backup DB and ran the TM1, now the issue is in the application folder ,some excel reports are added which are already removed and some recent reports are missed .
But users confirmed data is fine only problem with excel report in TM1 application folder.
Can any body have the solution if is there any supporting files need to be restored or where i have to check?
Thank you
TM1 Application Folder
manchala
- OLAP Product: Cognos BI,Cognos TM1
- Version: Cognos TM1 5.1
--Kumar
Re: TM1 Application Folder
If you "restored" by copying over the whole data directory it will have also copied the }applications folder which contains the relevant blob files and the }externals folder which will hold the actual sheets (assuming they have been added as actual sheets as opposed to references.)
