Defining Rule Calculation
krithika331
Post by krithika331 »
I have a rule calculation to be defined for ratio (x/y). I tried to define it in the general way as z = N: (x/y) and also z= C: (x/y) for both the Leaf and consolidation level. I came across a different situation where the resultant value is giving the some junk value (numeric with decimal) and the not the actual result of x/y. I am using 10.2 version. But when i have removed defining the qualifier (N or C) , i.e. z = (x/y) the ratio values gave me the correct values. I defined the Feeders for both x and y. But this will decrease the performance without defining the qualifier.
I didn't had this issue when worked with 9.5.2 version. Any ideas??
Thanks in advance !!
Re: Defining Rule Calculation
krithika331 wrote:Hi,
Do you have the AllowSeparateNandCRules parameter set in your tm1s.cfg file? If so, what is is it set to?
krithika331
I have checked the Tm1s.cfg file and the value for AllowSeparateNandCRules parameter is T. Is there any other property to be set in the cfg file.
Thanks in Advance !!
Version: PA 2.0.7
Post by jim wood »
Have you tried ['Z'] = (X\Y);
Or is the calculation different for both N and C? Also have you made sure that you are using \ and not /???
Jim.
