I have a requirement to copy data from one cube dimension element into a different cube but divide the data among different elements of a dimension.
In case that's not clear, Say in Cube ABC, I have 'amount' 100 for 'Department ID' 001. I want to load this 100 amount into my another cube XYZ
for 'Department ID' 001, but divide it(100) equally for each employee (in Employee dimension) (say 5 employees are in Dept 001). So Emp1 will have amount 20, Emp2 will have 20 and so on..
My current situation is, I am able to load 'amount' 100 for Department ID 001 from cube ABC into cube XYZ for Department ID 001, but its 100 for each employee.Which Is not right. I want 100 to get divided among employees for each Department ID.
The data in Cube XYZ should be like this : (But currently it's 100 for each employee in Department 1)
Amount
Department ID Employee
1 10001 20
10002 20
10003 20
10004 20
10005 20
Can you give me a hint how to do it using TI.
Thanks.
