I am currently facing an issue in TI Process that is working fine in functionally but while processing records, i am not getting usual behavior as TI process should display. I am using this TI to process around 2 Lakhs records and up to 50K records, it takes very less time that is normal but after that it takes more time to process each record and time taken to complete processing all records is around 10 times to time taken to process 50k records. Please help me with possible reasons that what can be issue here that is causing this delay. Your expert opinion is highly appreciated.
