10.2 - Adding named subsets to export views
Post by David Usherwood »
I was training yesterday using 10.2 (with the 'classic' tools :) ) and started showing the customers how you can add a named subset to an export view, allowing you to update a clearance view by just updating the subset.
But....
It didn't work - the named subset didn't attach to the view (albeit the subset contents did).
:cry:
I've checked with 10.1.1 - fine.
And running ViewSubsetAssign in a TI is fine.
Have others found this?
Re: 10.2 - Adding named subsets to export views
One of the bugs that has annoyed the hell out of me in 10.1 is that you can't attach a dynamic MDX subset to a view, only the elements get saved to the view. No problem with static subsets. Sounds like it isn't fixed in 10.2. It never occurred to me to use ViewSubsetAssign with TI as a workaround, I'll have to give that a go.
Gabor
Post by Gabor »
PI07206 manual Subsetassignment to ViewExtract is not saved, fixed with IF1(new) build 40547.
http://www-01.ibm.com/support/docview.w ... wg24037000
