I have a process that uses ODBCOpen(), ODBCOutput() and ODBCClose()
If the ODBCOutput() function calls a procedure on the remote database and that fails, how do I ensure that the ODBCClose() function is always called so that the connection is always closed?
I've tried the ODBCClose() in Prolog and Epilog but in either case, if the ODBCOutput() call fails, the ODBCClose() is not run and the connection remains open on the remote database.
Any suggestions welcome!
Andy
Ensuring ODBC connection is closed
- Version: [2.x ...] 11.x / PAL 2.0.9
- Excel Version: Excel 2013-2016
Re: Ensuring ODBC connection is closed
There is a known issue, which is addressed with TM1 10.2 FP1 IF2.
PI09375 ODBC connections TM1 server leaves ODBC connections open to Oracle when the TM1 process fails
I think you need to involve support to see if there is a Fix available for your version and if it catches your problem.
Unfortunately most fixes only reside in private sections of Fix Central these days.
Gabor wrote:There is a known issue, which is addressed with TM1 10.2 FP1 IF2.
Hi Gabor,
Thanks for that. We've just done an upgrade to 10.2 in our dev system, so we'll check it there
Andy
Please keep in mind, 10.2 FP1 has a build number 39992, but you need to look for a build 40547 (IF2) or higher.
Thanks, Gabor
I'm not sure what the build is that has just been installed - so have sent a request to find out
Andy
Andy
- Version: 10.2
The interim fix mentioned is officially termed Interim Fix 1 by IBM, however there seems to be some confusion on IBMs part with the accompanying documentation which states IF2 in places.
Another option might be to Open and close connections in a master process and run a sub-process to do the ODBC outputs. That way you can do something like:
ODBCOpen(....);
sResult = ExecuteProcess('ODBCOutputTI');
ODBCClose(...);
ODBCOpen(....);
ODBCClose(...);
Hiwhitej_d wrote:The interim fix mentioned is officially termed Interim Fix 1 by IBM, however there seems to be some confusion on IBMs part with the accompanying documentation which states IF2 in places.
ODBCOpen(....);
ODBCClose(...);
According to our consultant, the fix was issued on 24 Feb and does include the fix for ODBC connections - so, we'll be installing that at some point
I did try something similar to your example - however, each process wanted its own ODBC connection (ie, you can't pass the connection between processes), so the subprocess wouldn't run unless it had its own ODBCOpen/Close function calls which, of course, brings you back to Square 1!
Andy
After a major issue with MTQ (Multi Threaded Query) IBM has decided to back out the prior Interim Fixes IF1 & IF2 and combine both into a new "IF1" and make this one available in the public area of Fix Central. Version 10.2.102.40547.
http://www-01.ibm.com/support/docview.w ... wg24037000
