You are not allowed to use TM1RunTI.exe with CX.Andy Key wrote:CX (as a product that you can buy rather than trials or partner versions) is a 64-bit Windows product only.winsonlee wrote:apart form having the limitation of the 100 licenses for Cognos express 10.1, what other major difference there is between Cognos BI 10.1 + cognos tm1 10.1 ?
All CX components must run on the same hardware server with a maximum of 32 cores.
The integration of the various components relies on there being a single TM1/ICAS/Xcelerator server called CXMD.
CX is not licensed to use BI or another CX instance as a datasource, being limited to text and ODBC sources.
Given that CX instances are not allowed to talk to each other, there is no Replication.
CX Reporter is a limited set of the various Studios that are available for the full BI suite, so no Analysis Studio, no Event Studio, no Metrics Studio.
The exe file is not in the install package but the description is in the CX TI documentation so we asked and got official statement...
