Is it possible to install just TM1 (Xcelerator) components from Cognos Express ? A standard Cognos Express installation included other components which we do not need to run TM1, and default security is using CAM.
I tried to look into the installation folder and managed to find some x32/x64 MSI but it doesn't run with an error saying GUI installation is not permitted. I guess the MSI is packaged to be invoked as a command line installation.
Anyone ?
Install TM1 ONLY in Cognos Express
Re: Install TM1 ONLY in Cognos Express
Don't think so. But you can install the core stuff, then Excelerator, which is TM1, and not bother with Advisor(EV) and Reporter (Cognos BI). Also, you need 64 bit for a production install.
Herman Moller
David is correct. You have to install the Administrator portal and then you will be able to install the TM1 Client on the user machines.
