I'd like extend my deepest appreciation to you all as today will be my last day to still be able to keep my access as TM1 Administrator and certainly having a good glimspe of view or views of my TM1 model.
I started using TM1 on July 28th 2005 without a single clue about what it is not to mention slice and dice.
I have kept my role for over 4 years and finally today I have to raise my white flag to TM1.
I have learnt a lot from this forum. It has helped me to resolved a lot of work problems and overcome my difficult times in dealing with technical issues relating to TM1. The power of this forum is far beyond one can expect if one uses know how to use it!
I have definately gained the benefit but unfortunately I have to call it off.
Life consisting many dimensions and sometimes, some elements in it just require permanent elimination in order to make the "cubes" work efficiently !
Until then, if you wish to keep in touch with me , click accounts contact in http://www.networkpro.co.nzand your email will come to me.
